Small Block Rocker Stands, Anyone Make Them Anymore?
#2637806
03/27/19 05:42 PM
03/27/19 05:42 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I'm looking at a set of heads someone killed the rocker shaft pedestals off of, perhaps to put on something T&D rockers or something Anyway, I want to be able to run stock style rocker shafts and gear. Does anyone make a non-offset shaft stand? Does anyone even still make the offset stands for W2 rocker systems anymore?
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Small Block Rocker Stands, Anyone Make Them Anymore?
[Re: Michael Ecks]
#2637911
03/27/19 10:42 PM
03/27/19 10:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
https://angeluccimfg.com/collections/allYou could give them a call...they make the w2 rocker stands.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Michael Ecks]
#2638324
03/29/19 01:33 AM
03/29/19 01:33 AM
Posts: 43,252 Bend,OR USA
Cab_Burge
I have some W2 steel stands and maybe a set of aluminum also, PM me on here if your interested in buying a set. I was going to use them on another build but that has not happened and probably won't happen now.
