how much backspacing are on mopar cop wheels?? #263776
03/23/09 07:50 PM
03/23/09 07:50 PM
Clinton Twp. Michigan
coronet1966d Offline OP
just wondering the factory backspacing on the 15x7 slotted cop rims. im running them now on the d100 and they sit in to far. im buying some grag lites or pro stars and need about an inch less backspacing
Re: how much backspacing are on mopar cop wheels?? [Re: coronet1966d] #263777
03/23/09 08:44 PM
03/23/09 08:44 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
4.25" I'm guessing.
Re: how much backspacing are on mopar cop wheels?? [Re: Neil] #263778
03/23/09 08:46 PM
03/23/09 08:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
4.5 I think
Re: how much backspacing are on mopar cop wheels?? [Re: Neil] #263779
03/23/09 09:40 PM
03/23/09 09:40 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
4.25" I'm guessing.
I think 4.25" is correct.
You might ask over at www.dippy.org
Re: how much backspacing are on mopar cop wheels?? [Re: In_The_Pink] #263780
03/23/09 09:42 PM
03/23/09 09:42 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
4.25
Re: how much backspacing are on mopar cop wheels?? [Re: Michael] #263781
03/24/09 08:33 AM
03/24/09 08:33 AM
scratchnfotraction Offline
mine were 4 1/4 back set
my drag skinnys are 3 1/2" wide and 1 1/2" back set
if you go 1" less back set I think the front wheel will be out flush with the side of the fender on a 7" rim and could cause clearance probs with full wheel travel and turning maybe
my 7" rim has 4 1/2" back set and is just right...but does look a bit shallow on the dish side for a 7" rim
Re: how much backspacing are on mopar cop wheels?? [Re: scratchnfotraction] #263782
03/24/09 06:40 PM
03/24/09 06:40 PM
under hard throttle im rubbing on the insides of the rear wheel wells. id only be using the less backspace on the rear wheels and i may go with skinnys on the front
Re: how much backspacing are on mopar cop wheels?? [Re: coronet1966d] #263783
03/25/09 09:45 AM
03/25/09 09:45 AM
OH! I gots it now...
yea that should work out fine and stop the rubbing
watch the rain with the skinnys the brakes get wet and stay wet
but they get plenty of air for working them hard
and I just dig the way they look on a truck too
