L vs R Motor Mount #2636836
03/25/19 09:28 AM
03/25/19 09:28 AM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
Last week I pulled the 440 from my Charger, and found out both motor mount brackets were for the driver's side. Does this affect anything, or are both brackets supposed to be offset the same direction? If anyone has pictures comparing the L and R motor mounts, it'd be very appreciated.
Re: L vs R Motor Mount [Re: 70charger512] #2636851
03/25/19 09:44 AM
03/25/19 09:44 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Sorry I don't have a picture of mine to show, but the left one has the tube welded across the channel--the right one does not. That's how I tell them apart.
The rubber mounts themselves are the same.
Not sure if this will affect anything alignment-wise--I've never tried fitting two of the same ones.
They are easy to find at the swaps and online for not much money, though if you decide to make it "correct".
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: L vs R Motor Mount [Re: 70charger512] #2636949
03/25/19 12:47 PM
03/25/19 12:47 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
If you use two passenger side mounts alignment will be ok. Problem will be if you try to remove the drivers side in the car it will be a [censored]. Factory used one long bolt and sleeve to ease removal in the car....ask me how I know!!
Re: L vs R Motor Mount [Re: 70charger512] #2637241
03/26/19 08:09 AM
03/26/19 08:09 AM
NC
#1 Thread Starter
#1 Thread Starter
NC
Ok thanks, I actually have two driver's side brackets (with the tube), does that affect anything?
Re: L vs R Motor Mount [Re: 70charger512] #2637327
03/26/19 11:55 AM
03/26/19 11:55 AM
moparx Offline
moparx  Offline
i think only a longer bolt needed.
beer
