518 shifts into 4th by itself? #2634356
03/19/19 10:53 AM
03/19/19 10:53 AM
Jamestown, Indiana
James74 Offline OP
James74  Offline OP
Jamestown, Indiana
Put a non lockup 518 in my 74 road runner last summer. Wired up the OD solenoid with a toggle switch. Once I got driving the car, I found that the transmission will shift into 4th without the switch, and then slips if I try to get it to downshift by accelerating. I completely unhooked the power and the ground, so that there is no power going to the solenoid. The transmission will still shift into 4th by itself. Is this the OD solenoid, or a problem with something in the transmission? I thought if its just a valve body fix, I might try to fix it and drive it this summer. If I have to pull the transmission, I will probably just get it rebuilt. Engine is a 400/451, hughes 3k converter, jvx adapter, new 3.73 gears. Transmission is unknown condition; although I put a transgo kit in it before the install. Thanks for any help!
Re: 518 shifts into 4th by itself? [Re: James74] #2634647
03/19/19 11:43 PM
03/19/19 11:43 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
i had a similar problem with a 518 trans,turns out there was a spring missing in the valve body,only way we found it was by comparing another valve body to the one with a problem,your results may differ!!
my ladder of success is missing some rungs
Re: 518 shifts into 4th by itself? [Re: rhad] #2636803
03/25/19 08:43 AM
03/25/19 08:43 AM
Jamestown, Indiana
James74 Offline OP
James74  Offline OP
Jamestown, Indiana
BTT....so it sounds like this might be one of the valves in the valve body? I followed the TranGo instructions...no leftover parts haha. Would a bad solenoid cause this?
Re: 518 shifts into 4th by itself? [Re: James74] #2636809
03/25/19 08:59 AM
03/25/19 08:59 AM
Guitar Jones Offline
How/when does it shift into 4th? Does it shift 1/2 then 2/4 or does it shift to 2/3 and then immediately into 4th or is there a delay?
Re: 518 shifts into 4th by itself? [Re: James74] #2636811
03/25/19 09:03 AM
03/25/19 09:03 AM
A727Tflite Online content
A727Tflite  Online Content
Does it shift in to third, then waits a bit then shifts in to 4th or does it go from 2nd to 4th.
Regarding the slip - take it for a ride in manual low - get the engine up to about 3000 then get off the throttle.
Does the engine slow the car or does it just want to coast and free wheel?
Re: 518 shifts into 4th by itself? [Re: James74] #2636858
03/25/19 09:53 AM
03/25/19 09:53 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I have put my share of Transgo kits in 904s and 727s without any real problems. But when I tried to install the Transgo kit in my 518, I had nothing but problems. None of them were the same as yours, but several that I was not able to resolve. I finally had A&A build me a valve body and all is good.
If you can get an unmolested valve body somewhere, I would start with trying that and see what you have.
twocents
Master, again and still
Re: 518 shifts into 4th by itself? [Re: DaveRS23] #2636860
03/25/19 09:56 AM
03/25/19 09:56 AM
twocents
I had nothing but problems with the TransGo kit in my 48RE. Ended up taking most all of it back out.
Re: 518 shifts into 4th by itself? [Re: Guitar Jones] #2636901
03/25/19 10:43 AM
03/25/19 10:43 AM
moparx Online content
moparx  Online Content
what should one look for in a "molested" valvebody ? i have never had one in my hands, but i have a full manual trans-go kit i will be installing at some point.
beer
