Symptoms of old gas #2636555
03/24/19 05:59 PM
03/24/19 05:59 PM
North Carolina
469runner Offline OP
North Carolina
It was a beautiful day today, decided to take the Charger out for a cruise. It would hardly run, ran really poorly, refused to idle and was sluggish to accelerate, even backfired a couple of times. Once up to speed it smoothed out fine. It had a 1/2 tank of gas when it was parked and I used Startron Gas conditioner. Today I filled the tank with fresh fuel, hopefully it will get better as I drive the old gas out.
Re: Symptoms of old gas [Re: 469runner] #2636574
03/24/19 06:41 PM
03/24/19 06:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Could be a number of things. How old was the fuel and was it ethanol based ?
Regardless I'm thinking more along the lines of a sticky / contaminated needle and seat twocents
Re: Symptoms of old gas [Re: 469runner] #2636625
03/24/19 08:41 PM
03/24/19 08:41 PM
I would think that if it was from bad gas that if it acted up at idle/accel that it would do the same at higher speed(s).
Re: Symptoms of old gas [Re: TJP] #2636867
03/25/19 10:05 AM
03/25/19 10:05 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Carb is probably going to need to be pulled apart. I would expect your needle/seat or primary jets or idle circuit is partially plugged.
Re: Symptoms of old gas [Re: DaytonaTurbo] #2636903
03/25/19 10:50 AM
03/25/19 10:50 AM
moparx Offline
moparx  Offline
when was the last time the carb was apart ? today's gas leaves deposits that like to play havoc with the old carbs. nothing real serious if you have been running it somewhat frequently, but they do require more service these days than "back in the day".
beer
