Duster ralley dash #2635793
03/23/19 08:04 AM
03/23/19 08:04 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I was under the impression that you could not put ralley gauges into a dash frame that came with standard gauges.
Is this true? The ralley dash frame is different than a standard dash frame?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Duster ralley dash [Re: cdstl] #2635802
03/23/19 08:42 AM
03/23/19 08:42 AM
las vegas,nv
mopar muscle7271 Offline
las vegas,nv
That is true,you need a rally dash frame for the gauges to fit.you would need a rally dash harness as well.i did the conversion on my 71 dart. If cant find a 70-71 rally frame. You use a 67-69 cuda rally dash frame and weld up the igintion hole on frame.
Re: Duster ralley dash [Re: cdstl] #2635904
03/23/19 12:07 PM
03/23/19 12:07 PM
CA
crackedback Offline
crackedback  Offline
CA
It's not hard to mod a stock frame to accept a rallye set up.
Re: Duster ralley dash [Re: crackedback] #2636025
03/23/19 05:12 PM
03/23/19 05:12 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
What are the differences? I'm not planning on it but another guy that I know is.
I was fairly certain that the frames were different, but he didn't think so.
Re: Duster ralley dash [Re: cdstl] #2636183
03/23/19 10:08 PM
03/23/19 10:08 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Size of the hole is the difference, same as the girl you date versus the one you marry
[img]https://www.forabodiesonly.com/mopar/attachments/71_duster_dash_frame1-jpg.1714972960/[/img]
eBay-cdwmotorsports
Re: Duster ralley dash [Re: cdwmotorsports] #2636648
03/24/19 09:24 PM
03/24/19 09:24 PM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
That is not a rally dash frame or close to one.
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
