68 Road Runner Trunk Trim Panel Installation #2635839
03/23/19 09:56 AM
03/23/19 09:56 AM
Mountain View, CA
68rrunner Offline OP
Mountain View, CA
Putting my Road Runner back together after paint. Got to the trunk trim panel and I would assume there should be gaskets that go between the body and the panel? Can't seem to find anything doing some general web searching.
Thanks for any help!
Re: 68 Road Runner Trunk Trim Panel Installation [Re: 68rrunner] #2635858
03/23/19 10:34 AM
03/23/19 10:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Do you mean the exterior Decor Package trim panel?
Mine didn't have any gaskets, only a little strip caulk around the fasteners.
Also should mention a common error is to have the red area color too light; should be more of a maroon.
Kind of matches the shade of the unlit tail lamps.
My Decor Group '68 I'm using for reference was an original car, untouched original everything.
Re: 68 Road Runner Trunk Trim Panel Installation [Re: topside] #2635993
03/23/19 04:29 PM
03/23/19 04:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Same here with my '68's trunk "finish panel" nothing but some white caulk as I think a sort of thread lock for the stud nuts IIRC. Also totally agree with the maroon/dark red color for the finish panel. I'm still mad about how some "pro" restored it after talking, sending emails, photos of 3 original finish panels and putting notes in with the panel that I sent it to him. It came back lighter maroon than I requested and to top it off he could see right away when he got it that it was DARK MAROON and almost an exact match to the tail lights mad
Re: 68 Road Runner Trunk Trim Panel Installation [Re: A12] #2635996
03/23/19 04:32 PM
03/23/19 04:32 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
Similar panel on my old 68 GTX, no gasket. Same for 69 with the smaller piece for that matter
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: 68 Road Runner Trunk Trim Panel Installation [Re: topside] #2636016
03/23/19 04:58 PM
03/23/19 04:58 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Went through a few photos and realized there are fiber or felt like washers on the studs between the finish panel and the trunk lid like these.
Re: 68 Road Runner Trunk Trim Panel Installation [Re: A12] #2636019
03/23/19 05:02 PM
03/23/19 05:02 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Mine had the same washers. More like a flattened foam similar to some of the other body gaskets.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 68 Road Runner Trunk Trim Panel Installation [Re: RoadRunner] #2636027
03/23/19 05:17 PM
03/23/19 05:17 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Thanks you're right they are foam like and you could probably make them from sheet foam that is used for most electronic packaging currently. If you've ever seen the foam that is used on or between the front brake backing plates and the spindles it's very similar or the same?
Re: 68 Road Runner Trunk Trim Panel Installation [Re: A12] #2636209
03/23/19 11:13 PM
03/23/19 11:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Oops, I forgot about the foam seals on the panel.
