Page 18 of 34 1 2 16 17 18 19 20 33 34
Re: Starting to work on the Duster [Re: AndyF] #2635463
03/22/19 08:34 AM
03/22/19 08:34 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Awesome engine, very nice build!
Though... there must be a typo hidden somewhere, since 580 torque @5800 equals 640 of them good oregonian horses.
580torque@4800 does make more sense to me.
Re: Starting to work on the Duster [Re: stickman60] #2635514
03/22/19 10:46 AM
03/22/19 10:46 AM
AndyF Online content OP
AndyF  Online Content OP
You are correct, I was trying to do too many things at the same time. Peak torque was 580 @ 5200 rpm but it also had 570 @ 3000 rpm and 500 @ 6200 rpm so it was really a big flat torque curve. Not perfectly flat, kind of a rolling hill type of torque curve for some reason. Should run fine in the car though.
Re: Starting to work on the Duster [Re: AndyF] #2635518
03/22/19 10:51 AM
03/22/19 10:51 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Quote
I am sure it will!
Re: Starting to work on the Duster [Re: AndyF] #2636642
03/24/19 09:12 PM
03/24/19 09:12 PM
I wanted to dimple the 3 inch holes in the cowl support but the 3 inch dimple die isn't available in a bolt together, only in a press style. So I bought the press type dimple die and had a machine shop modify it and then make me a big press bolt. Worked like a charm. Just took a few twists of the wrench to dimple those holes. They look a lot better after they are formed.
Re: Starting to work on the Duster [Re: AndyF] #2636658
03/24/19 09:36 PM
03/24/19 09:36 PM
birdtracker Offline
birdtracker  Offline
Looking good!! Birdtracker
Re: Starting to work on the Duster [Re: AndyF] #2660196
05/28/19 11:40 PM
05/28/19 11:40 PM
A buddy helped me with some minor body work on the front clip. Just some sanding and seam sealing. Basic prep work and then we rolled it into the booth for some color.
Re: Starting to work on the Duster [Re: AndyF] #2660280
05/29/19 11:33 AM
05/29/19 11:33 AM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
Really nice, can't wait to see it done.
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Starting to work on the Duster [Re: aspenrt360] #2660319
05/29/19 12:42 PM
05/29/19 12:42 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
The time and effort into this build is super. This will be one nice ride when it is complete.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Starting to work on the Duster [Re: AndyF] #2660682
05/30/19 05:35 PM
05/30/19 05:35 PM
I let the paint dry in the sun for a few days and then started hanging parts back on it. It is a lot nicer working on a clean shiny car than how it was before.
Re: Starting to work on the Duster [Re: AndyF] #2660713
05/30/19 06:54 PM
05/30/19 06:54 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
looks really nice!
Re: Starting to work on the Duster [Re: Forest] #2660717
05/30/19 07:04 PM
05/30/19 07:04 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Originally Posted by Forest
looks really nice!
iagree I like the "Spinaker White". It looks great! Provides a nice contrast for any factory stripes.
Re: Starting to work on the Duster [Re: Forest] #2661145
06/01/19 09:47 AM
06/01/19 09:47 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Looks great, Andy! Now that all the hard stuff is done, it should be fun to put it all back together knowing that everything bolts right in.
2 kids and a dog
Re: Starting to work on the Duster [Re: TonyS451] #2661621
06/02/19 07:12 PM
06/02/19 07:12 PM
Working on the Viper brake install today. It is nice when everything is clean. Sure beats laying on my back having dirt and gunk drop in my eyes every time I turn the wrench!
Re: Starting to work on the Duster [Re: AndyF] #2661744
06/03/19 08:26 AM
06/03/19 08:26 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Man that looks great! I cant wait to get to that point on my demon build
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Starting to work on the Duster [Re: AndyF] #2661748
06/03/19 08:39 AM
06/03/19 08:39 AM
Germany
stickman60 Offline
stickman60  Offline
Germany
Looks like on a factory assembly line back in the day... only they didn't have Viper brakes back then. cool
Re: Starting to work on the Duster [Re: AndyF] #2661802
06/03/19 11:09 AM
06/03/19 11:09 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Be prepared for nhra techs to occasionally beach about the brake line across the firewall.
Re: Starting to work on the Duster [Re: @#$%&*!] #2662089
06/04/19 04:25 AM
06/04/19 04:25 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looks great Andy; I really love white A bodies up
Re: Starting to work on the Duster [Re: AndyF] #2662432
06/04/19 11:03 PM
06/04/19 11:03 PM
Getting ready to lift the engine and transmission into place. I decided the starter was a little close to the headers so I gave the starter the gold foil treatment. Hopefully this helps keep the heat down.
Re: Starting to work on the Duster [Re: AndyF] #2663599
06/07/19 07:02 PM
06/07/19 07:02 PM
I decided to switch to a set of Firm Feel upper control arms so I had to grind a little bit of clearance. Once a small piece of sheet metal was ground off the arms fit just fine. The FFI upper arms will give me a little more caster plus they look nicer than my old original ones.
Re: Starting to work on the Duster [Re: AndyF] #2663626
06/07/19 08:38 PM
06/07/19 08:38 PM
Huntsville, AL
Airwoofer Offline
Airwoofer  Offline
Huntsville, AL
Thank you - much easier on the eyes with those tubular UCAs. One step closer to losing the torsion bars too.
