Re: after 46 years - finally getting at it
[Re: Stanton]
#2635326
03/21/19 07:54 PM
03/21/19 07:54 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
What about the drivetrain? What's it going to get?
[Re: Dave Hall]
#2635432
03/22/19 05:38 AM
03/22/19 05:38 AM
Posts: 4,768 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Sounds like it is one heck of a powerful fun car done up exactly how you want it. very nice.
Keep old mopars alive.
[Re: Stanton]
#2635470
03/22/19 08:55 AM
03/22/19 08:55 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2635503
03/22/19 10:21 AM
03/22/19 10:21 AM
The Don
The Don
[Re: cdwmotorsports]
#2635699
03/22/19 08:43 PM
03/22/19 08:43 PM
Posts: 855 ontario canada kingston
aspenrt360
That is cool! hope you get it done in good time and done right. then you can have some fun!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
[Re: Stanton]
#2635733
03/22/19 11:00 PM
03/22/19 11:00 PM
Posts: 8,393 Highland, MI.
Sunroofcuda
Highland, MI.
What's up with the HUUUUGE intake ports on the tops of the firewall?
[Re: Sunroofcuda]
#2635737
03/22/19 11:07 PM
03/22/19 11:07 PM
Posts: 8,868 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
What's up with the HUUUUGE intake ports on the tops of the firewall? twin turbos !!!
[Re: Stanton]
#2635840
03/23/19 10:00 AM
03/23/19 10:00 AM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
Good for you. Sounds like its going to be done right and the combo sounds like its going to be a blast to drive. I'm more a fan of the factory orange, if our votes count at all Keep us posted on the progress
2 kids and a dog
[Re: TonyS451]
#2635865
03/23/19 10:50 AM
03/23/19 10:50 AM
Posts: 20,165 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Very nice. Can’t wait to see it finished
[Re: Stanton]
#2636078
03/23/19 07:04 PM
03/23/19 07:04 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
A few tried and true suggestions from personal experience...
* Full US Cartool Chassis stiffening kit. * Run a 5 or 6 speed and 4.10's * Keep the car up off the ground enough so it can be driven on the open road at speed. * Make sure it can run on pump premium with a larger than stock fuel tank. * Run Nitto Drag Radials out back and at least a 149mph rated front tire. (you won't be as nervous when you stretch it up over 150mph on occasion.) *spend a bit more now instead of regretting saving a few bucks here and there. Besides, once it's done, you have no car payments.
Mine took just shy of 4 decades and 5 years for restoration. It seems a while back now, but I learned some of the above lessons along the way. It still keeps getting better each year.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2636163
03/23/19 09:43 PM
03/23/19 09:43 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
* Full US Cartool Chassis stiffening kit. have their frame connectors and torque boxes. Haven't decided on the other front end pieces yet. * Run a 5 or 6 speed and 4.10's Hemi 4-speed and probably a 3.54 gear. Motor is cammed for bottom end. * Keep the car up off the ground enough so it can be driven on the open road at speed. Yeah - nothing done to lower the car substantially. Stock style front end. Caltracs out back. * Make sure it can run on pump premium with a larger than stock fuel tank. Stock style EFI tank. * Run Nitto Drag Radials out back and at least a 149mph rated front tire. (you won't be as nervous when you stretch it up over 150mph on occasion.) Good tip - wheel/tire combo to be determined BUT will NOT be running big rims with rubber band tires - I like the look of a big tire wall on these older cars *spend a bit more now instead of regretting saving a few bucks here and there. For the past ten years of building the motor, trans and accumulating parts I have not cut corners (other than the 440Source stroker kit - which I have complete faith in). Money is no object. Wasted enough and got ripped off enough in the past. That's one reason its taken so long, seeking out the right qualified people to do the work I can't. This won't be a million dollar trailer queen but it won't be a cobbled together piece of crap either.
[Re: Stanton]
#2702775
10/01/19 09:43 PM
10/01/19 09:43 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
UPDATE:
So I got the car back last Friday after 6 months at the sheet metal guy's place. I pretty happy with the work. Last night I decided to answer two questions that have been on my mind ... 1) car the engine be installed from below with the headers attached (Dougs 452's)? and 2) will everything fit under the 6-pack scoop (RB with Indy single plane and a '70 air cleaner. Well, the answers are YES and YES . The scoop is 3" tall and it looks like I should have about 1" of clearance. The biggest hangup for the engine install was the dipstick tube but there was enough flex in it to go.
