Painting Valve Covers #2634690
03/20/19 08:15 AM
03/20/19 08:15 AM
LEE, MASS
TOMRR Offline OP
TOMRR  Offline OP
LEE, MASS
Have to redo my valve covers on my 440,, after sand blasting should I use etching primer ? or clean and just use a good high temp paint.
Tomrr
Re: Painting Valve Covers [Re: TOMRR] #2634714
03/20/19 09:14 AM
03/20/19 09:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Tomrr
Painting an engine/components I usually put down a coat of etch primer followed by a coat of Single Stage/ straight Enamel, avoid the spraycan crap....
Re: Painting Valve Covers [Re: DAYCLONA] #2634794
03/20/19 12:06 PM
03/20/19 12:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I always make sure there's mechanical & chemical adhesion on engine tin, and even when I've had to use rattle-can topcoat, never had a flaking or peeling problem.
Re: Painting Valve Covers [Re: topside] #2634847
03/20/19 02:20 PM
03/20/19 02:20 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
Powder coating works well.
Re: Painting Valve Covers [Re: varunner] #2634978
03/20/19 08:59 PM
03/20/19 08:59 PM
5thAve Offline
5thAve  Offline
I clean well and go straight to rattle can engine paint. Never had a problem with it peeling or looking bad.
Re: Painting Valve Covers [Re: TOMRR] #2635025
03/20/19 11:39 PM
03/20/19 11:39 PM
AndyF Offline
AndyF  Offline
I rattle canned these valve covers. Cheap engine paint from NAPA.
Re: Painting Valve Covers [Re: AndyF] #2635076
03/21/19 07:56 AM
03/21/19 07:56 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Just don't sandblast the inside of the valve covers.........
Re: Painting Valve Covers [Re: Gavin] #2635146
03/21/19 10:56 AM
03/21/19 10:56 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
3X that Make sure all openings are securely sealed as the abrasive and dust gets into everything. beer
Re: Painting Valve Covers [Re: TOMRR] #2635201
03/21/19 12:39 PM
03/21/19 12:39 PM
Greenfield, Tennessee, USA
CudaChick1968 Offline
Valve covers typically don't get that hot so high temp paint is kind of overkill. Don't feel restricted on your options ... here's a few ideas from my work stash.
Ed Ward MPs.jpgAdam Hall Dress Up layout.jpgGreg Reynolds MPs.jpgGeorge Keuchmann after.jpg
Leanna ~ The CudaChick
Owner/Operator
http://PhoenixSpecialtyCoatings.com
731.613.9192 (10 a.m. - 9 p.m. Central)
Exceptional Custom Powder Coating & Metal Restoration
Re: Painting Valve Covers [Re: CudaChick1968] #2635526
03/22/19 11:04 AM
03/22/19 11:04 AM
None
71rm23 Offline
71rm23  Offline
None
whistling
Re: Painting Valve Covers [Re: 71rm23] #2635535
03/22/19 11:23 AM
03/22/19 11:23 AM
Heh hehhhh .... thanks Rod!!!!
Owner/Operator
Re: Painting Valve Covers [Re: TJP] #2635581
03/22/19 01:26 PM
03/22/19 01:26 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I glassbead or sandblast EVERYTHING body or engine/driveline wise inside and out with ZERO issues, you just have to have an OCD attitude about blowing out/cleaning the part(s)/component(s) afterwards
Re: Painting Valve Covers [Re: DAYCLONA] #2635608
03/22/19 02:48 PM
03/22/19 02:48 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Mopar brand rattle can.
2 kids and a dog
Re: Painting Valve Covers [Re: DAYCLONA] #2636795
03/25/19 08:25 AM
03/25/19 08:25 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Yes, as long as you have the OCD it will be OK...but really OCD, not just a spray with brake kleen. Sand can get embedded in the metal, or collect under the baffles etc, and several people found that out the hard way when their fresh engine had glass or sand in the oil after breakin. I'm not sure how many people would take enough care. But if you do, should be OK. Stakes are high though.
Re: Painting Valve Covers [Re: Gavin] #2636853
03/25/19 09:46 AM
03/25/19 09:46 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
I wire brushed mine, cleaned everything white glove clean with brake cleaner, and sprayed a couple coats Plasti-Kote engine paint on the bare metal.
Looked great and held up perfectly for the 10 years I had the car. Simple.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Painting Valve Covers [Re: CudaChick1968] #2637082
03/25/19 06:47 PM
03/25/19 06:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Depends on the manifolds ! work
