reverse shifter pattern detent plate ? #2632196
03/13/19 10:05 AM
03/13/19 10:05 AM
moparx Offline OP
moparx  Offline OP
does anyone make a reverse pattern detent plate [PRN123] for a 68-70 B-body console shifter ? TIA.
beer
Re: reverse shifter pattern detent plate ? [Re: moparx] #2632251
03/13/19 12:05 PM
03/13/19 12:05 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I recall a company that advertised in MCG having detente shifter conversion plates for console 68-70 B body automatics, as to whether they offered reverse pattern I don't know, but perhaps you have an MCG to look thru or others will hopefully chime in
Re: reverse shifter pattern detent plate ? [Re: DAYCLONA] #2632262
03/13/19 12:26 PM
03/13/19 12:26 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Re: reverse shifter pattern detent plate ? [Re: CSK] #2632376
03/13/19 05:54 PM
03/13/19 05:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I believe CRT bought out the original company/patent. That's the only place I've been able to see them listed. The old place was shiftRgate.
Doug
Re: reverse shifter pattern detent plate ? [Re: CSK] #2633308
03/16/19 12:06 PM
03/16/19 12:06 PM
moparx Offline OP
moparx  Offline OP
Originally Posted by csk
thanks ! i knew someone made a detent plate for converting a console shifter into a slapstick kinda deal, but that was years ago, and it was only for a forward pattern valvebody. i didn't know the original guy was bought out by our own mr. cope.
again, thanks guys ! up
beer
Re: reverse shifter pattern detent plate ? [Re: moparx] #2634969
03/20/19 08:39 PM
03/20/19 08:39 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
I was Tom's "test mule" for his reverse pattern Shift-R-Gate about 15 years ago...still works great! No more missed 2nd gear!
1MYTGTX
Re: reverse shifter pattern detent plate ? [Re: 1MYTGTX] #2635556
03/22/19 12:08 PM
03/22/19 12:08 PM
moparx Offline OP
moparx  Offline OP
that's good to here. where did you get your gear indicator indicator number plate ? beer
Re: reverse shifter pattern detent plate ? [Re: moparx] #2635687
03/22/19 08:00 PM
03/22/19 08:00 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Its a custom decal. I believe I got it from Tom at Duncan Motorsports (Shift-r-gate)
1MYTGTX
