Page 6 of 6 1 2 3 4 5 6
Re: BB Street heads for mild 505 [Re: TonyS451] #2634754
03/20/19 11:02 AM
03/20/19 11:02 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Nice car, Tony....very cool indeed smile
Rich H.
Esse Quam Videri
Re: BB Street heads for mild 505 [Re: AndyF] #2634803
03/20/19 12:19 PM
03/20/19 12:19 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Originally Posted by AndyF
I know you cheated. I saw a second grader sitting at your computer earlier.
On a somewhat related note, I've dyno tested two 500 inch Mopar big blocks this week with Trick Flow 240 heads and hyd roller cams. Both engines required a bunch of fuel and timing at cruise to keep from burning up the exhaust. The big problem was right around 2000 rpm with a slight load. Roughly equal to driving down a flat freeway at 70 mph. The tune file that was working in my Coronet last summer would not work in either of these engines. The EGTs would go skyhigh and the engine would shut down. We ended up adding a bunch of timing (35 to 40 degrees) and adding some fuel and then they were happy.
I do not know what is going on but I suspect it has to do with how well the Trick Flow 240 heads flow at low lift. Perhaps the intake charge is getting sucked into the exhaust or something like that. Anyway, just keep an eye on your engine if you are out cruising on the freeway. Your carb might fat enough already but I really doubt you have much ignition advance at 2000 rpm since you don't have vacuum advance on that MSD. So you are probably running low to mid 30's and you don't have any way to get more advance than that.
That's great info Andy. I did change the advance bushing in the dist should give me about 20 degrees initial at 36 total. Also swapped out the springs to lighter ones. Funny you say this because on initial startup for cam break in, ( although it started up perfectly on my initial dist setting), the header tubes started to glow after a couple minutes. It was running great so my buddy wasnt quick on the timing light. Once he noticed the headers glowing I just shut it down. Started back up and and saw the timing was at 30. Bumped it up to 34 and glowing stopped and was fine for the remainder of cam break in. Not sure where jetting is at, but I'll definitely keep an eye on that too. I only drove it a couple miles and no freeway time yet. All i know is it feels much faster than the old set up.
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2634806
03/20/19 12:27 PM
03/20/19 12:27 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks Zippy, Brad, GY3, BSB67, Krautrock, MarkM and Fast68 for the nice words. A special thanks to Dwayne for the custom Comp cam and also for your great technical advice .
As for the exhaust tone, I also agree the new set up sounds better. Hard to tell from the videos, but the solid ft is not much noisier at all. The car overall is louder, but I am OK with that smile .
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2634902
03/20/19 04:44 PM
03/20/19 04:44 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
When are you planning to do the carb swap?
Re: BB Street heads for mild 505 [Re: BradH] #2634906
03/20/19 05:05 PM
03/20/19 05:05 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Maybe this weekend or Monday, if weather cooperates. I'm looking forward to it! I'll definitely keep you posted.
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2635118
03/21/19 09:48 AM
03/21/19 09:48 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Got an early start on installing the new Brad H carb. It was just about dead on out of the box! Havnt road tested yet, but so far works nice, and looks sweet too!
I think these will work better than the radial ta's
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2635333
03/21/19 08:08 PM
03/21/19 08:08 PM
BradH Offline
BradH  Offline
wrench
Re: BB Street heads for mild 505 [Re: BradH] #2636675
03/24/19 10:07 PM
03/24/19 10:07 PM
BradH Offline
BradH  Offline
Tony - Are you sending the carb back for a refund or what? laugh2
Re: BB Street heads for mild 505 [Re: BradH] #2636794
03/25/19 08:24 AM
03/25/19 08:24 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
No way, Brad. Running great ootb, but I do appreciate the extra tuning parts you uncluded w the carb. See, here's video proof of it running with the Brad950...it's been road tested too and pulls strong w no stumbles or hesitation smile
https://youtu.be/BaOzBbh5YNg
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2636797
03/25/19 08:30 AM
03/25/19 08:30 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I greatly prefer that idle quality and rpm to the other two up
But I tend to like it on the faster side.
Here is a link to my pile-0-Krap
(Brad helped me out as well, with calibration advice)
https://www.youtube.com/watch?v=iB34vRlCKtQ
Rich H.
Esse Quam Videri
Re: BB Street heads for mild 505 [Re: ZIPPY] #2636810
03/25/19 09:03 AM
03/25/19 09:03 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Yeah, the other videos were taken a little prematurely when the car was cold. Brad also reminded me
I should try to keep the idle up at least 1k to try to keep as much oil splashing on the solid ft cam. Your car sounds awesome! Definitely something serious under the hood smile
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2636819
03/25/19 09:10 AM
03/25/19 09:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Cold explains alot of it, then.
Agree 100% for oiling, and thanks...just thought it'd be fun to compare, I clicked back and forth
between yours/mine a couple times smile
Rich H.
Esse Quam Videri
Re: BB Street heads for mild 505 [Re: ZIPPY] #2636830
03/25/19 09:21 AM
03/25/19 09:21 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I just tried that too. Your car sounds better IMO. Its got a little more chop to it, which I like. Car looks sweet too, a classic mopar street beast! Checking the gas station for victims ...
2 kids and a dog
Re: BB Street heads for mild 505 [Re: TonyS451] #2637236
03/26/19 07:47 AM
03/26/19 07:47 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Ah, it's probably just smaller CI and bigger (duration) cam.
The body is pretty bad. ...It looks best in the dark laugh
But thank you just the same up
Rich H.
Esse Quam Videri
Re: BB Street heads for mild 505 [Re: ZIPPY] #2638158
03/28/19 04:24 PM
03/28/19 04:24 PM
Get-X Offline
Get-X  Offline
I've heard the same thing about my body as well...…...and the car too whistling
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: BB Street heads for mild 505 [Re: Get-X] #2638863
03/30/19 02:36 PM
03/30/19 02:36 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Just a quick update. I ordered a set of advance bushings for my MSD pro billet so I could run 20* initial and 34 total. The biggest bushing in the kit that comes w the dist is 18* and only allows for 16 initial, if u need 34 total. Anyhow, board member crackedback makes a 10* and 14* advance bushing, and I can confirm that his 14 is dead on. 22 bucks for both and very quick shipping. Another Moparts member coming through with a nice product up
2 kids and a dog
