Who makes correct generic looking 440ci tall valve covers #2633389
03/16/19 03:20 PM
03/16/19 03:20 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
My 1970 Charger has a period correct 1970 block and I'd like to keep it looking as original (as possible) but my oversize rockers do not fit under my 1970 valve covers.
I have a decent set of chrome (Milodon) valve covers and they look cool but not 70's correct.
Does anyone make a set of tall valve covers without embossed lettering and something that looks relatively generic (correct) that I can paint engine hemi orange to match my motor.
If there is noting available, do I just cut the baffle out of my current valve covers?
Thanks in advance,
Mike
Re: Who makes correct generic looking 440ci tall valve covers [Re: Texican] #2633396
03/16/19 03:29 PM
03/16/19 03:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Would those Uber-thick 1/4” gaskets get you the clearance?
Re: Who makes correct generic looking 440ci tall valve covers [Re: Pacnorthcuda] #2633430
03/16/19 06:13 PM
03/16/19 06:13 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
How about these from Indy Cylinder Head? Says they're tall and fit stock or Indy heads. I've thought about buying a set just because of the added rigidity.
popcorn
John
Re: Who makes correct generic looking 440ci tall valve covers [Re: SattyNoCar] #2633434
03/16/19 06:42 PM
03/16/19 06:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Supercuda] #2633437
03/16/19 06:59 PM
03/16/19 06:59 PM
SattyNoCar Offline
SattyNoCar  Offline
$130 for spacers? shock
Summit has a plain (but polished) cast aluminum valve cover too. Summit Linky
popcorn
John
Re: Who makes correct generic looking 440ci tall valve covers [Re: SattyNoCar] #2633439
03/16/19 07:12 PM
03/16/19 07:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm sure with some effort you can find ones cheaper than that.
In the comments for the Summit covers is this gem
"Good valve covers, good quality. Only problem they do not clear aftermarket rocker shaft. "
Re: Who makes correct generic looking 440ci tall valve covers [Re: Supercuda] #2633453
03/16/19 08:31 PM
03/16/19 08:31 PM
SattyNoCar Offline
SattyNoCar  Offline
I didn't see that comment at Summit. That seems like it would be an error on the buyer as Summit clearly shows the dimensions of the cover. hammer
John
Re: Who makes correct generic looking 440ci tall valve covers [Re: SattyNoCar] #2633465
03/16/19 08:55 PM
03/16/19 08:55 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
That's the problem with a lot of comments on Summit's stuff. Operator error. Either they ordered the wrong size, didn't install it correctly or once in a blue moon the part was defective. Been dealing with Summit for 20 years and never had a problem but have seen plenty of people blame them for their own stupidity.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Who makes correct generic looking 440ci tall valve covers [Re: Centerline] #2633477
03/16/19 09:31 PM
03/16/19 09:31 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure how operator error applies to a valve cover fitting or not fitting an aftermarket rocker shaft.
Also int eh comments is the inside dimension, that might help the OP decide if it might work.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Supercuda] #2633597
03/17/19 11:03 AM
03/17/19 11:03 AM
moparx Online content
moparx  Online Content
what doesn't "fit " ? width ? height ? length ?
too much left out.
beer
Re: Who makes correct generic looking 440ci tall valve covers [Re: moparx] #2633608
03/17/19 11:32 AM
03/17/19 11:32 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
too much left out.
beer
Exactly. Have no idea what problem he is trying to solve.
And depending on what the problem is, there are usually ways to solve it without buying new valve covers.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Texican] #2633615
03/17/19 11:50 AM
03/17/19 11:50 AM
AndyF Offline
AndyF  Offline
How about these billet valve covers? Do they look stock enough for you?
Re: Who makes correct generic looking 440ci tall valve covers [Re: AndyF] #2633924
03/18/19 07:36 AM
03/18/19 07:36 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have the no-logo Indy cast covers, and they required some clearancing to fit over the ends of my aftermarket rocker arm shafts because they're slightly longer. No big deal, took a few minutes with a Dremel rotary grinder to create some small "channels" deep & wide enough to let the vcs slide over the rocker shafts.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Texican] #2634004
03/18/19 11:10 AM
03/18/19 11:10 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I am going to be the guy who talks about what folks did before there were any fancy speed parts.
Take two sets of valve covers, cut the first pair say 2" from the flange, cut the second pair 1" from the flange, then weld or braze the top from the
second pair on to the first pair, and presto.
Note I wouldn't actually do this...I would just get something else and wouldn't sweat whether it has a stock appearance quite so much.
I have no logo Indy covers on rpm heads, with comp pro magnum rockers, no clearance issues.
Rich H.
Esse Quam Videri
Re: Who makes correct generic looking 440ci tall valve covers [Re: ZIPPY] #2634421
03/19/19 01:31 PM
03/19/19 01:31 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Don't remember where I saw this but someone took a pair of the Aluminum Moroso covers and Hammer-and-dollied the "letters" flat then painted 'em.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Jwilli500] #2634502
03/19/19 05:29 PM
03/19/19 05:29 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Fullmetaljacket..... It was on the Jenny Craig thread.
Re: Who makes correct generic looking 440ci tall valve covers [Re: AndyF] #2634584
03/19/19 08:58 PM
03/19/19 08:58 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Andy, your covers look super nice & would look great on my 383.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Triggerfish] #2634606
03/19/19 09:39 PM
03/19/19 09:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the Summit brand cast valve covers with RAS shafts and holdowns on Indy EZ heads and they fit with some slight trimming and enlarging the holes
Gus beer
64 Plymouth Savoy
Dana 60
Re: Who makes correct generic looking 440ci tall valve covers [Re: fourgearsavoy] #2634970
03/20/19 08:40 PM
03/20/19 08:40 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
[quote=fourgearsavoy]I have the Summit brand cast valve covers with RAS shafts and holdowns on Indy EZ heads and they fit with some slight trimming and enlarging the holes
Gus beer [/quote
I've only used factory valve covers and have used Isky, Crower, Crane ductile iron, Cane Aluminum 1.6, and Comp Pro Magnums rockers with only minor baffle work to the VC.
Re: Who makes correct generic looking 440ci tall valve covers [Re: Triggerfish] #2634995
03/20/19 10:08 PM
03/20/19 10:08 PM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
Andy what brand are the valve covers?
