Low pressure power steering hose - OE style? #2634472
03/19/19 03:46 PM
03/19/19 03:46 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Looking for recommendations on OE style low pressure power steering hose for a 1970 440 with Saginaw pump. Not necessarily needing NOS or repop with part numbers etc.
It appears most modern 3/8 ID hose has a smaller OD than back in the day. I have purchased 2 different types and the factory style clamps fit too loosely and will not provide clamp pressure. I assume the wall thickness of the older hose styles must have been thicker. Let me know what works with factory style red band clamps? Thanks! Joe
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2634494
03/19/19 05:01 PM
03/19/19 05:01 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
Joe,
try this one.
http://www.billrolikenterprises.com/proddetail.asp?prod=2537699%2DP
mike
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: Low pressure power steering hose - OE style? [Re: mdwyer] #2634500
03/19/19 05:23 PM
03/19/19 05:23 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I believe it was 11/32 hose. It was a special hose 3879925 IIRC.
Re: Low pressure power steering hose - OE style? [Re: mopars4ever] #2634517
03/19/19 06:30 PM
03/19/19 06:30 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yes it is an 11/32 hose as you stated above not 3/8"
Ron
Re: Low pressure power steering hose - OE style? [Re: RJS] #2634686
03/20/19 08:03 AM
03/20/19 08:03 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ron
Correct, and is still avail thru any mopar dealer
Re: Low pressure power steering hose - OE style? [Re: gtx6970] #2634718
03/20/19 09:29 AM
03/20/19 09:29 AM
Lansing, MI
Lansing, MI
Thanks to all for the recommendations!
After more investigation I went ahead and ordered the repo date coded hose kit from Bill Rolik. I hope this is the solution!
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2634777
03/20/19 11:41 AM
03/20/19 11:41 AM
WA
tman Offline
tman  Offline
WA
Some years ago, I got one of those reproduction date coded return hoses that came with red clamps. Looks like similar packaging on the Rollick site. The hose ended up swelling and softening up after about a years use. Hose came right off when I was backing my car and squirted fluid all over the place. There have been many others that used repro return hoses and had the same issue. Hope they changed out the hose type on your order. I ended up buying Gates 11/32 ps return hose and no issues for years now. There is a photo of what the hose looks like when it fails on this link. That is what my hose looked like when it failed. There was a similar discussion about this hose on Moparts, but could not find it.
https://forum.e-bodies.org/engine-t...turn-hose-leaking/2970/msg43763#msg43763
Re: Low pressure power steering hose - OE style? [Re: tman] #2634833
03/20/19 01:37 PM
03/20/19 01:37 PM
Lansing, MI
Lansing, MI
Thanks for the info. I sent a note to Bill asking him about any reported issues with these hoses. Hoping he has some information.
FYI - Actual factory part number for this hose is 2537699. It seems most everyone is offering a 3/8 ID hose as the replacement for the factory 11/32.
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2634890
03/20/19 04:15 PM
03/20/19 04:15 PM
WA
tman Offline
tman  Offline
WA
I tried 3/8 and its too loose. All current parts book say 3/8, which is 1/16 bigger then 11/32. 11/32 hose must be getting harder to get. But as others say, you can get the correct size hose at Dealers.
Re: Low pressure power steering hose - OE style? [Re: tman] #2635572
03/22/19 12:53 PM
03/22/19 12:53 PM
N.W. INDIANA
moparjohn Offline
moparjohn  Offline
N.W. INDIANA
Joe,
I had a reproduction power steering return hose swell up like a cooked hot dog after about a year.
I was able to find a NOS hose part number 2537699 and all has been well since!
MJ
Re: Low pressure power steering hose - OE style? [Re: moparjohn] #2635607
03/22/19 02:48 PM
03/22/19 02:48 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Anybody know if the late model B vas used this type of hose?
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2635746
03/22/19 11:29 PM
03/22/19 11:29 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
This is the hose I purchased from Yearone...about 20+ years ago. The YO part number is FD9925 and is still listed on their website. It is supposed to be what Chrysler sells out of their parts department. The date code on this 2 ft. section is 0092 (1992?). Due to its age, I will not use it. I think the Gates 11/32 hose is the best option. I am leery of many reproduction hoses: heater, fuel, vapor, etc. The quality looks questionable. I usually buy Gates products and wipe off all the lettering with lacquer thinner, resulting in a nice nondescript hose. Sure, your minus the Pentastar, part number, date code, "KV", etc., but you have peace of mind.
David
Re: Low pressure power steering hose - OE style? [Re: David1971] #2635763
03/23/19 01:14 AM
03/23/19 01:14 AM
Lansing, MI
Lansing, MI
Thanks for the additional suggestions!
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2635908
03/23/19 12:26 PM
03/23/19 12:26 PM
New York
rarefish Offline
rarefish  Offline
New York
Here is a couple of pics of a 2537699 NOS hose that I have.
Re: Low pressure power steering hose - OE style? [Re: rarefish] #2636063
03/23/19 06:30 PM
03/23/19 06:30 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: Low pressure power steering hose - OE style? [Re: David1971] #2636128
03/23/19 08:54 PM
03/23/19 08:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
David
I just installed that same hose on my 71 Bee last year
I also had it sitting in the attic for about ten years before installing
My 71 Bee still had the factory hose on it if you can believe that , well the numbers on the hose made me believe that and I have owned the car since 1984
Anyways , I guess I will look that hose over very soon when I pull the car out of winter hibernation within a month
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Low pressure power steering hose - OE style? [Re: bee1971] #2641146
04/04/19 12:31 PM
04/04/19 12:31 PM
Lansing, MI
Lansing, MI
I ended up ordering the Gates 11/32 instead of the repop hose kit. Fits perfectly. Thanks for the suggestions.
Re: Low pressure power steering hose - OE style? [Re: 70gtx440dana] #2644099
04/11/19 04:08 PM
04/11/19 04:08 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I’ve had the same issue with the swelling reproduction hose on two different cars😡
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
