TFI type coil bracket idea #2634430
03/19/19 01:51 PM
03/19/19 01:51 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
E-core TFI coils are inexpensive and produce a nice spark, and this is good.
They're a little awkward to mount, and this is bad.
Here is an idea I had for big block applications.
I'm really not sure about the appearance of it.
What do you think? Too Ugly?
Rich H.
Esse Quam Videri
Re: TFI type coil bracket idea [Re: ZIPPY] #2634434
03/19/19 01:56 PM
03/19/19 01:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks fine, and I'm sure you'd round off the corners.
I just mount them with a piece of aluminum angle stock using the 2 holes on one side of the coil, but I haven't mounted one in that location yet.
One of the beauties of those coils is they can be oriented in any location.
I like to use the OEM-style pigtail connector.
Re: TFI type coil bracket idea [Re: topside] #2634451
03/19/19 02:24 PM
03/19/19 02:24 PM
I wonder how it would look with coil/bracket painted intake color
Re: TFI type coil bracket idea [Re: ZIPPY] #2634558
03/19/19 07:59 PM
03/19/19 07:59 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The bracket is fine, functional and looks great. twocents
Now how about a cover of some sort to hide the rest of it shruggy
beer
Re: TFI type coil bracket idea [Re: TJP] #2634603
03/19/19 09:32 PM
03/19/19 09:32 PM
that beast would take some getting used to
Re: TFI type coil bracket idea [Re: RapidRobert] #2634681
03/20/19 07:48 AM
03/20/19 07:48 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
It's pretty ugly. The aftermarket ones costing 4 or 5x as much with aluminum brackets integrated
Are slightly better but still awkward appearing in my opinion.
I'm pretty well done running canister coils on anything I care about, so maybe
I just need to get over the appearance and stop thinking old school.
No big deal....thanks for the input.
Rich H.
Esse Quam Videri
Re: TFI type coil bracket idea [Re: ZIPPY] #2634700
03/20/19 08:36 AM
03/20/19 08:36 AM
Torq37 Offline
Torq37  Offline
A few mounting options on ebay if you search "TFI coil bracket"
Re: TFI type coil bracket idea [Re: ZIPPY] #2634707
03/20/19 08:51 AM
03/20/19 08:51 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I wonder if the vertical orientation for the connections is the best choice? For the coil wire, a 90* boot would work. But it would seem that the electrical plug-in would be better off coming in from the left or right rather than straight up. Just wondering. work
Master, again and still
Re: TFI type coil bracket idea [Re: DaveRS23] #2634711
03/20/19 09:07 AM
03/20/19 09:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
not mine
Re: TFI type coil bracket idea [Re: Torq37] #2634752
03/20/19 10:59 AM
03/20/19 10:59 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Yeah, I actually bought one of those.
There's a good print out there on a jeep forum too, for diy.
I'll kick this idea around for awhile yet, it doesn't need to be solved anytime soon.
Rich H.
Esse Quam Videri
