Hemi Swap to B-Body
#2634170
03/18/19 07:46 PM
03/18/19 07:46 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I am thinking of putting a 66 Hemi into my 67 GTX. Do you think it would be ok to use the existing torsion bars or should I upgrade to Hemi torsion bars. Its going to be a restored driver car. I think there are ones for 440 and ones for hemi? Thanks.
RS23L7 4-Speed
Re: Hemi Swap to B-Body
[Re: Mopar_Mike]
#2634177
03/18/19 07:56 PM
03/18/19 07:56 PM
Posts: 12,201 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The original 318 torsion bars are holding up the Hemi in my mostly street Cuda. Been that way for years. Try the ones you have. If there is something about them that you don't like, it is no big deal to change them later.
Master, again and still
[Re: Mopar_Mike]
#2634187
03/18/19 08:12 PM
03/18/19 08:12 PM
Posts: 529 SW CO
HemiSportFury
SW CO
With aluminum heads, intake and water pump housing the Hemi probably would weigh less than your 440.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: Mopar_Mike]
#2634199
03/18/19 08:46 PM
03/18/19 08:46 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I am thinking of putting a 66 Hemi into my 67 GTX. Do you think it would be ok to use the existing torsion bars or should I upgrade to Hemi torsion bars. Its going to be a restored driver car. I think there are ones for 440 and ones for hemi? Thanks. If it's a GTX it should already have stout factory bars in it capable of "supporting" the HEMI, but if they're tired 50+ year old bars, now's the time for an upgrade in suspension and braking IMHO as well as a freshening of the front end components, and if you have an anemic 8 3/4 trailing out back, a Dana 60 is your best friend behind a HEMI...
[Re: Lee446]
#2635915
03/23/19 12:43 PM
03/23/19 12:43 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
The 440 and Hemi bars are the same. Those 50 year old bars are most likely made of better steel than the aftermarket stuff available now. Some of you guys seem to think as soon as you drop the Hemi in the original T-bars are going to snap into pieces. This isn't GM crap.
Sheldon
[Re: RUNCHARGER]
#2635944
03/23/19 02:09 PM
03/23/19 02:09 PM
Posts: 529 SW CO
HemiSportFury
SW CO
Agree. I've found rear leaf springs to sag and get weak over time, but not the same with torsion bars. I had both torsion bars break on a 57 Plymouth I had when I was in HS, but no problem at all with any of my later cars, and I have around 70 combined owner years with 64 Plymouths plus 11 more with E-bodies. Replaced rear leaf springs on all those cars, but never a torsion bar.
