Valve Spring Question #2633857
03/17/19 09:49 PM
03/17/19 09:49 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Putting together a 340 for my son's car and thinking about running the .508 purple shaft cam. What valve spring should I run with this setup? Heads currently have the single with a damper.
Re: Valve Spring Question [Re: Hunted Duck] #2633898
03/18/19 12:31 AM
03/18/19 12:31 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
When I ran a 340 & liked to pedal it spiritedly, i found the stock springs were kinda too soft for the stock style valve. After a couple of changes I found Comp Cams 920 spring, installed @ 1.7 worked great & didn't hammer the lock area of the valve. The std valve is heavy, look for lite weight valves & drive it like you stole it.
Re: Valve Spring Question [Re: rebel] #2634400
03/19/19 12:38 PM
03/19/19 12:38 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Watch the guide/seal to retainer clearance......Might want to check that first.
