Stage V heads #2632891
03/15/19 07:52 AM
03/15/19 07:52 AM
spartanburg sc
topcat53 Offline OP
topcat53  Offline OP
spartanburg sc
I have a set of P4529993 stage V cast iron heads for a RB block. According to manufacture info these require a special offset intake rocker. Does anyone in group happen to have any info on this special rocker arm? I am in search of a set. I don;t know what the difference in these special offset rockers vs. the stock ones.
Re: Stage V heads [Re: topcat53] #2632895
03/15/19 08:07 AM
03/15/19 08:07 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
those rockers were made by crane. the stage v's I have are clearance around the intake port and didn't really need the offset rockers. I did use the offset rockers though with poor results. the fulcrum centerline on the offsets I have are all in different positions which would wear the intake guides quickly. I couldn't set up proper geometry with them.
Re: Stage V heads [Re: lewtot184] #2632897
03/15/19 08:14 AM
03/15/19 08:14 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
contact 440 source, they might have rockers that provide more clearance.
Re: Stage V heads [Re: Hemidavey] #2632927
03/15/19 10:01 AM
03/15/19 10:01 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
another thing to look at is valve stem clearance in the guide. mine were very loose from the factory.
Re: Stage V heads [Re: lewtot184] #2633027
03/15/19 01:34 PM
03/15/19 01:34 PM
spartanburg sc
topcat53 Offline OP
topcat53  Offline OP
spartanburg sc
Thanx for your reply. How old are the heads you have? I have to take a closer look at mine. So,you ended up using the standard intake rocker arms instead of the Crane?
Re: Stage V heads [Re: topcat53] #2633030
03/15/19 01:45 PM
03/15/19 01:45 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i bought mine in the mid '90's. all I used with them was the crane gold offset 1.5 rocker, but I could have used the standard rocker. I used the offset because it was recommended; big mistake. there's two versions of the stage v; early has no heat crossover and later does. mine have the heat crossover.
