Stock Steering Coupler or Flaming River U-Joint? #2631895
03/12/19 02:00 PM
03/12/19 02:00 PM
Wisconsin
wkroncke17 Offline OP
Wisconsin
All,
I got one of the Flaming river Steering U-joints in a package parts buy, and I'm considering putting it on my car while its apart.
I got directions off of the website, so it doesn't seem too difficult.
Question is, is this a good reliable part?
Is it worth it and do you notice a difference?
Do you gain any room under the hood? It seems only a bit smaller.
Looking for any other pros-cons of this setup.
Thanks everyone in advance!!
Wally.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2631902
03/12/19 02:13 PM
03/12/19 02:13 PM
Chicago
PurpleBeeper Offline
Chicago
I personally don't see any advantage to using the flaming river u-joint unless you have a custom build & some weird steering geometry
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2631919
03/12/19 02:38 PM
03/12/19 02:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The U-joint doesn't allow for any in/out movement as the frame flexes, the factory pot joint does.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: John_Kunkel] #2631968
03/12/19 04:37 PM
03/12/19 04:37 PM
Wisconsin
Wisconsin
Very good point.....
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2631985
03/12/19 05:37 PM
03/12/19 05:37 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
do those u joints have enough length to convert from a power steering box to manual?
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: krautrock] #2632065
03/12/19 09:10 PM
03/12/19 09:10 PM
Wisconsin
Wisconsin
Yes, it has a built in extension. Kinda pricey though, about $300 if memory serves me correctly?
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2632066
03/12/19 09:11 PM
03/12/19 09:11 PM
Wisconsin
Wisconsin
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2632133
03/13/19 02:08 AM
03/13/19 02:08 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
Could work if you break the shear pins in the column...
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: wkroncke17] #2632203
03/13/19 10:19 AM
03/13/19 10:19 AM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
I got one to get a small amount of additional header clearance.
I have had it for several years with no issues.
One thing it has going for it is it will not pull apart like a stock one can.
I was with a friend many years ago at the track when he had one come apart and left him with no steering in the lights. It was a Super Stock 67 Hemi four speed Belvedere II car and the constant tugging on the steering wheel while changing gears pulled the steering column up enough to pull it apart. Fortunately he was able to only drive it a little off the end of the track.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: 340Cuda] #2632322
03/13/19 03:33 PM
03/13/19 03:33 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
If you use anything but the factory plunge coupler you will wear out your column bearings prematurely.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: Montclaire] #2632406
03/13/19 08:04 PM
03/13/19 08:04 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Isn't there a rotational velocity variation per rotation with using a single joint vs a double joint.
Not sure if it is noticeable, an irritant, or whatnot.
I used a double joint, which also I think would allow some s steering shaft offset in a crush accident.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: 340Cuda] #2632539
03/14/19 08:36 AM
03/14/19 08:36 AM
PA
KGorney Offline
KGorney  Offline
PA
I always put one of these clamps on my couplers. Prevents the eventual separation that seems to always occur on the stock couplers without it. Seems like most cars I've had never seemed to have one.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: KGorney] #2632624
03/14/19 12:35 PM
03/14/19 12:35 PM
I've own Mopars starting with several 1957 Chrysler and a 1959 Dodge and multiple 1962 to 1971 A,B and E body cars.
I've never seen or heard of that retainer, I like it up
What brand, part number and where I can I buy them help work
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: Cab_Burge] #2632640
03/14/19 01:17 PM
03/14/19 01:17 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I don't recall all the particulars on it but, there was someone making those a few years ago but then they quit making them.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: Jwilli500] #2632644
03/14/19 01:25 PM
03/14/19 01:25 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Upon further investigation see here for $10:
https://www.ebay.com/i/291757502737?chn=ps
OEM can be had for about $15 too
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: Jwilli500] #2632677
03/14/19 03:02 PM
03/14/19 03:02 PM
PA
KGorney Offline
KGorney  Offline
PA
Yeah, I hadn't ever seen them on any Mopars I owned, but once I found out about them I put one one every one since!
They are readily available from many eBay sellers.
I usually get the stainless steel version from Detroit Muscle Technologies
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: Montclaire] #2632712
03/14/19 04:44 PM
03/14/19 04:44 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I have off the shelf universals on both of my cars one has been on it for over 10,000 miles and I have had no problems. I believe there are a few different mopar specific ones, manual to manual, power to power, and power column to manual box.
Re: Stock Steering Coupler or Flaming River U-Joint? [Re: JAMESDART] #2633021
03/15/19 01:19 PM
03/15/19 01:19 PM
Wisconsin
Wisconsin
You're talking about a Universal joint like the Flaming River Joint, not the stock coupler, correct?
