Re: Rear end question
[Re: slomoshun]
#2632452
03/13/19 10:04 PM
03/13/19 10:04 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
Did you verify that the ring and pinion gears have the original matching # gear set etch into both of them? If not do that next If they have them you should be able to get them set up properly If not a matching # gear set you are on your own Are you using a pinion depth tool or trying to go by the pattern ?
[Re: slomoshun]
#2632457
03/13/19 10:15 PM
03/13/19 10:15 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
How tight is your pinion preload? So how does it turn by hand when you grab the ring gear and rock it back and fourth? It sounds like the pinion is binding on the ring gear. How was your pattern was it in the middle? Did you try and coat the teeth with super slippery grease yet? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: slomoshun]
#2632632
03/14/19 12:48 PM
03/14/19 12:48 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I think what you're experiencing is the nature of hypoid gears, especially dry gears. It "locks up" forward because you don't have enough leverage when turning the ring gear.
[Re: John_Kunkel]
#2632639
03/14/19 01:11 PM
03/14/19 01:11 PM
Posts: 11,586 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Hypoid gears slide against each other. I've experienced this with smaller rears as well when the gears were clean and dry. Try a spritz of WD or something with some lubricity. Doesn't have to be dripping wet, just not bone dry.
