sebring won't start. #2630899
03/09/19 08:52 PM
03/09/19 08:52 PM
Elizabethton Tn
louie heaton Offline OP
Elizabethton Tn
01 sebring convertible, 2.7 won't start. Battery hot, turn switch, nothing, no clicking, grunting, groaning , nothing. Replaced the Starter relay, nothing, am going to replace the 40 amp ignition switch fuse tomorrow in the daylight. 130k miles, have never replaced the starter, but there has been no indication it was going bad, my daughter has been driving it... Any ideas?? Thanks.
70 T/A clone, Hensley built 440,(not much more than stock) Low 12's at Bristol,(17 miles from here)8 other various Mopars, used to have 800+ posts back around 2001.
Re: sebring won't start. [Re: louie heaton] #2630934
03/09/19 10:37 PM
03/09/19 10:37 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Very simple verify battery 12 volts at the big terminal and 12 volts at the little terminal when trying to crank. If you have both and a good ground to the starter its the starter. If you can hit the starter while trying to crank it may just make it spin. If so its still a time bomb and time to replace.
Re: sebring won't start. [Re: NITROUSN] #2630947
03/09/19 11:35 PM
03/09/19 11:35 PM
Elizabethton Tn
Elizabethton Tn
Thank you nitrousn, The dang battery is in the wheel well, can't even see it under the hood, can I check at those two outlets for jump starting under the hood?? I put a charger on it and it was good and hot, didn't actually check the voltage with a meter,, it doesn't make a sound when I turn the key, will probably have to jack it up, and get my daughter to turn the key while I "peck" on it....
Re: sebring won't start. [Re: louie heaton] #2630967
03/10/19 01:42 AM
03/10/19 01:42 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Had that problem a couple of times on our old '02. It is likely the starter fuse and the starter itself is drawing too many amps even if it is working.
Re: sebring won't start. [Re: louie heaton] #2630974
03/10/19 02:57 AM
03/10/19 02:57 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Even though it might seem like a silly question, it is in park correct?
Nothing in park or neutral?
Re: sebring won't start. [Re: SNK-EYZ] #2631069
03/10/19 12:25 PM
03/10/19 12:25 PM
Elizabethton Tn
Elizabethton Tn
Yes, it is in park, and tried neutral, and tried jiggling, had a pt cruiser, that the neutral switch was bad, then learned that they are built inside the tranny, what a bummer. replaced the starter relay, that didn't work, going to daughters house in a few minutes to try a new ignition switch 40 amp fuse,,, Is there a starter fuse itself???? will look in the fuse panel In the dash, didn't see one at the under hood fuse panel? Thanks guys for the ideas. Guess next step is jack it up and try the connections to the starter, then peck on it a little with a hammer.
Re: sebring won't start. [Re: louie heaton] #2631103
03/10/19 02:20 PM
03/10/19 02:20 PM
Elizabethton Tn
Elizabethton Tn
Jim Lusk,,, I replaced the ignition switch fuse, kind of a funny looking fuse, 4 bucks, still didn't work, BUT noticed when I tried it I didn't hear the fuel pump buzzing. Lo and Behold, there is a fuse marked start/fuel, pulled it , and it was blown, replaced it and it started right up, after spending 24 bucks, I had the fuse at home in my garage, but I left the starter relay and the ign. switch in and marked the ones in the boxes as good. THANKS guys for the input.
Re: sebring won't start. [Re: louie heaton] #2631280
03/10/19 11:53 PM
03/10/19 11:53 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yup, that's the fuse that blows when the starter is ready to be replaced. I put a new starter in and the fuse lasted more than a year and blew again. Replaced the starter again (lifetime warranty) and it held until the car was totaled.
Re: sebring won't start. [Re: Jim_Lusk] #2631401
03/11/19 11:46 AM
03/11/19 11:46 AM
moparx Offline
moparx  Offline
just something to look at quick on your starter. if the contacters have not been replaced since new, now's the time. they are in the box the battery hot post is connected. the set is cheap, and easy to replace. i have done that countless times, and nothing else needs done. when they become pitted, they will take too many amps to make contact, blowing that fuse. the starter motor and drivetrain are super reliable, and will go hundreds of thousands of miles, even with eleventybillion starts. you just occasionally change out the contactor set.
the other thing to look at, is the condition of the case itself. if you are in an area that uses those nasty chemicals on the road in the winter that cause rust, they also do bad things to the case. i have found if there are any cracks in the case [due to corrosion or otherwise], the starter will bind up, due to the case flexing at the crack when trying to start. if any cracks are found, it's time for a starter. a boneyard starter will be ok if you can get one, or buy new, your choice.
beer
Re: sebring won't start. [Re: moparx] #2631424
03/11/19 12:34 PM
03/11/19 12:34 PM
Elizabethton Tn
Elizabethton Tn
Moparx, what part exactly do I ask for at the parts store, are they the contacts that attach at the starter"??
Re: sebring won't start. [Re: louie heaton] #2631444
03/11/19 01:58 PM
03/11/19 01:58 PM
My hovercraft is full of eels
DaveKanofsky Offline
I'm having this exact same problem on an '01 Sebring convert, 2.7 L, 95k miles
No crank, found fuse blown, started no problem. Next start two days later, Blew the fuse, replaced fuse, started 3 times no problem. which is where I'm at now, with a bag of fuses in the console...
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: sebring won't start. [Re: DaveKanofsky] #2631659
03/11/19 11:59 PM
03/11/19 11:59 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
when you remove the front cover on the solenoid you will see a round disc and two L shaped copper contacts ,one on each side,those are the 3 pieces that need replaced,FYI the L shaped copper pieces are different from each other,its really a simple job,as they say.....even a caveman can do it
my ladder of success is missing some rungs
Re: sebring won't start. [Re: rhad] #2631799
03/12/19 11:02 AM
03/12/19 11:02 AM
moparx Offline
moparx  Offline
^^^^ this. caveman simple. over time, these contactors/contacts [all i've ever heard them called] become pitted and burnt from use [think welder]. when they get really bad, sometimes they work, sometimes they don't. when they don't, sometimes they click, other times, not. in some cases, [not very many though] you can sand the pieces to a shiny, copper color, and they will work for a while, but you will eventually need to replace them.
beer
Re: sebring won't start. [Re: moparx] #2632229
03/13/19 11:19 AM
03/13/19 11:19 AM
I haven't achieved caveman yet, Is a kit like this what you recommend?
https://www.ebay.com/i/191700929607?chn=ps
I assume the starter has to come out of the car?
Thanks!
MOPARS ONLY!
John 3:17
Re: sebring won't start. [Re: DaveKanofsky] #2632234
03/13/19 11:27 AM
03/13/19 11:27 AM
moparx Offline
moparx  Offline
yes. looks like it. appears to have gone up about 3bucks since the last time i bought one. the starter on the bench is the way to go. i never tried to change those out in the car, although on my old man's 1990 dynasty with the 3.3, i shined up the contactors enough to get it to start with the starter in the car. that gave me a day or so to get a set.
of course, my old man being himself, didn't bring his car around until it wouldn't start [again !]. laugh2
beer
Re: sebring won't start. [Re: moparx] #2632265
03/13/19 12:29 PM
03/13/19 12:29 PM
Cool, thanks!
MOPARS ONLY!
John 3:17
Re: sebring won't start. [Re: DaveKanofsky] #2632597
03/14/19 11:33 AM
03/14/19 11:33 AM
Follow up - Multiple sources confirm that there is no Plunger and Contact kit for the 2001 2.7L starter.
One response stated it is a Mitsubishi PMGR starter, and offered a complete solenoid, but how do I know if it's the same failure mode?
I have a totaled '05 Sebring convertible, 2.7 L that I can pull the starter from, but they list as different p/n's, so I'm trying to find out what's different and if they are interchangeable.
Any insight?
Thanks!
MOPARS ONLY!
John 3:17
Re: sebring won't start. [Re: DaveKanofsky] #2633324
03/16/19 12:26 PM
03/16/19 12:26 PM
moparx Offline
moparx  Offline
i apologize profusely that i lead you down the wrong road ! blush i ASSumed [and everyone knows about that !] your sebring had the denso starter.
so sorry fo getting your hopes up on an easy fix. i know nothing about a mitsubishi starter.
beer
Re: sebring won't start. [Re: moparx] #2634120
03/18/19 05:23 PM
03/18/19 05:23 PM
No problem at all, I appreciate the suggestion, would have been nice!
MOPARS ONLY!
John 3:17
