plating on strut rod nut on lower control arm #2631233
03/10/19 09:29 PM
03/10/19 09:29 PM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
Because my grand pop painted everything on the undercarriage of the car black, I want to detail everything back to the original colors. I know the lower control arms were bare metal and dipped in cosmoline and the strut rods were natural steel color as well. What was the color of the nut that held the strut rod to the lower control arm? Was that a gray phosphate color or was that like a clear zinc? Sorry, car is a 69 RR.
inherited a 69 roadrunner from my grand pop.
Re: plating on strut rod nut on lower control arm [Re: fuelishnsilly] #2631315
03/11/19 03:24 AM
03/11/19 03:24 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Is this it?
Plating code "S7" = Cadmium (light silver).
Available from amkproducts.com, page 45 under Bulk Hex Nuts.
Re: plating on strut rod nut on lower control arm [Re: kentj340] #2631316
03/11/19 03:42 AM
03/11/19 03:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Concerning the appearance of strut rods: yes, "natural steel color", but that covers a lot of territory.
Like many forged suspension parts, strut rods were hot worked and took on a bluish-black mill scale. You can closely duplicate the factory new appearance by getting them squeaky clean (de-rust, wire brush, scrub multiple times with "hot" solvent like laquer thinner or MEK, absolutely no fingerprints) and apply gun bluing, several coats. Follow with RPM wax.
Top rod is treated with bluing. Bottom one is untreated, "natural steel color". (The photo was taken under yellowish fluorescent light. In sunlight there would be a bigger difference between the two.)
Re: plating on strut rod nut on lower control arm [Re: kentj340] #2631462
03/11/19 02:51 PM
03/11/19 02:51 PM
Greenwood Lake, NY
Greenwood Lake, NY
Originally Posted by kentj340
Is this it?
No that is the front one that goes through the k frame. I need the plating on the taller / thicker one that has the fine threads at the control arm.
Re: plating on strut rod nut on lower control arm [Re: fuelishnsilly] #2631467
03/11/19 03:04 PM
03/11/19 03:04 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Check Bill Rolik and Frank Badalson for correct item.
Ron
Re: plating on strut rod nut on lower control arm [Re: fuelishnsilly] #2631532
03/11/19 06:54 PM
03/11/19 06:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Is this it?
Rear was black phosphate . Washer usually black phosphate as well,,although I've heard over the years some been found silver zinc ( never seen one myself )
Re: plating on strut rod nut on lower control arm [Re: gtx6970] #2631851
03/12/19 12:03 PM
03/12/19 12:03 PM
Greenwood Lake, NY
Greenwood Lake, NY
This appears to have a molded in washer. If I knew how to post a pic, I would
Re: plating on strut rod nut on lower control arm [Re: fuelishnsilly] #2632036
03/12/19 07:48 PM
03/12/19 07:48 PM
New Jersey Bada Bing
bremotorsports Offline
I have everything you need in correct finishes on my website.
www.billrolikenterprises.com
Go to Group 2 Suspension
201-394-5533 Cellular
Re: plating on strut rod nut on lower control arm [Re: bremotorsports] #2632453
03/13/19 10:04 PM
03/13/19 10:04 PM
Greenwood Lake, NY
Greenwood Lake, NY
Thanks Bill. I'll be in touch.
Re: plating on strut rod nut on lower control arm [Re: fuelishnsilly] #2632497
03/14/19 12:34 AM
03/14/19 12:34 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I told you to do that a bunch of posts up
Ron
