SS SPRING SELECTION #2631732
03/12/19 09:20 AM
03/12/19 09:20 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Should the SS spring squat to allow for weight transfer or stiff to force the axle down and to the ground for better tire contact? Better to go with weight rating less than the car for the spring to get that transfer?
Re: SS SPRING SELECTION [Re: A/MP] #2631777
03/12/19 10:39 AM
03/12/19 10:39 AM
fullmetaljacket Offline
I've always used a weight rating a little more heavier than what my car weighed. Not much these days. LOL
The spring has to stiffen and raise the car's body so the the differential goes the opposite way and plants into the ground, hence the tires bite and go. So in essence, Raise and plant. Good luck with the junk they make these days as far as springs.
Re: SS SPRING SELECTION [Re: fullmetaljacket] #2631790
03/12/19 10:51 AM
03/12/19 10:51 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
The best choice I have ever made on SS springs is to take them off an install CalTracs with their split monoleaf springs.
Re: SS SPRING SELECTION [Re: 340Cuda] #2631805
03/12/19 11:10 AM
03/12/19 11:10 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Be careful going to high on the spring rating. I put a set of 002-003 springs on my 1974 Duster that had been lightened and the car handled like crap going down the track wandering around. I took them to a local spring shop where we took them apart and dearched them some. That helped big time and I ended up going 9.80’s with them 30 years ago. With the track prep today they will and do work but if my budget allowed it I would go a different route.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SS SPRING SELECTION [Re: A/MP] #2631827
03/12/19 11:36 AM
03/12/19 11:36 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
After decades of searching for a compliant riding suspension that hooks up hard on the street and track, I ended up running a pair of passenger side 3200lbs SS Springs on both my 3700lbs A-Body & E-Body. Both cars transfer weight to the rear very effectively as the slapper bars simultaneously plant the tires harder than anything else I've tried.
I've heard all the stories and heard this set-up should never work on a Mopar, but it does. Even Robert Tarozzi, the guy who developed the SS Spring specs was impressed with how well the car hooked up.
The cars were spring wrapping the front spring segments with these lighter springs, so I modified some Lakewood slapper bars so they would fit properly on my Mopars. The results are nothing more than amazing.
The cars ride, handle and hook up harder than any other suspension set-up I've tried, including the Caltracs with split mono leafs, which were great on a smooth track, but gave WAY to harsh a ride on the open road. I do use high quality shocks on both cars.
Re: SS SPRING SELECTION [Re: jbc426] #2632131
03/13/19 02:03 AM
03/13/19 02:03 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Years ago when I knew less than squat, I got the 3800 lb ones for a 1970 Charger. Dear Lord the trunk lid was almost even with my armpit and I am 6'5. TOTALLY worthless. they work ok for a good street stomper but their day has past.
Re: SS SPRING SELECTION [Re: sasquatch] #2634283
03/19/19 06:02 AM
03/19/19 06:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I use 3400 lb springs on my 63 which weighs a bit over 3700 lbs . They have worked fine for me for the 10 plus years they have been on the car. Ron
Re: SS SPRING SELECTION [Re: 383man] #2634287
03/19/19 06:44 AM
03/19/19 06:44 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
Have the 002-003 on my 73 Duster which I put in recently with caltrac adjustable shocks set shock at 5 setting and rode like a buck wagon dropped to 1 smoothed out but I have at least 5"
of clearance between tire and fenderwell lip and I don't care for look should of kept old springs on had a nice stance with drag radials on it and hooked good.
Re: SS SPRING SELECTION [Re: 7074cuda] #2634312
03/19/19 08:48 AM
03/19/19 08:48 AM
an8sec70cuda Offline
I used to have the 3400 lb SS springs on my cuda that was 3700 lbs at the time. It hooked good, but the Cal-Tracs were way more consistent.
This was running 11.40s on motor w/ a 1.60 sixty foot and 10.60s on nitrous w/ a 1.50 sixty foot. Left front tire would be a foot in the air and the right front barely touching the ground. The Cal-Tracs evened it out.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: SS SPRING SELECTION [Re: an8sec70cuda] #2634358
03/19/19 10:57 AM
03/19/19 10:57 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I use the 3400# SS springs on a 3600# street/strip 12 second '67 Satellite that does a 1.68 60 foot on 255 drag radials.
Re: SS SPRING SELECTION [Re: an8sec70cuda] #2634411
03/19/19 01:00 PM
03/19/19 01:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Exact same experience here with nearly identical times. Cal-tracs are much more repeatable and consistent.
'63 Dodge 330
11.19 @ 121 mph
Re: SS SPRING SELECTION [Re: A/MP] #2634414
03/19/19 01:11 PM
03/19/19 01:11 PM
Any good drag race leaf spring should NOT squat tsk
You want the springs tp press the rear end and tires into the ground for maximum traction up work
If you decide to go with leaf springs only, they will work fine, contact Greg Luneack at Tri City Competion in San Carllos(I think that is the correct town near San Diego) CA for a custom made set that will hook your car very well scope
Re: SS SPRING SELECTION [Re: Cab_Burge] #2634423
03/19/19 01:33 PM
03/19/19 01:33 PM
PA.
"Little"John
"Little"John
PA.
I can’t remember the 60 foot times as it was many many years ago but my 1974 Duster ran 9.82 on Super Stock springs but I sure as heck wouldn’t go that direction today if I was starting fresh
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: SS SPRING SELECTION [Re: A/MP] #2634440
03/19/19 02:08 PM
03/19/19 02:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
They shouldn't squat. The axle should be forced down. The back of the car will rise up at the same time.
Mine are the 3800lb versions, but having not tried any others except these I don't know if it's better to use a lower rating.
Rich H.
Esse Quam Videri
Re: SS SPRING SELECTION [Re: Cab_Burge] #2634742
03/20/19 10:35 AM
03/20/19 10:35 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Tri City Competition is in San Marcos, right near where I live in Vista. I called him once and his springs are pretty expensive compared to regular SS springs, cost is right up there with getting Cal Tracs but I heard they work really well.
Re: SS SPRING SELECTION [Re: 67Satty] #2635284
03/21/19 04:15 PM
03/21/19 04:15 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Since we're talking about super stock springs.... Here's a question. How much HP do you guys think they'll handle @ 3300lbs before they say we're done? I'll be pushing 900hp this year and I'm starting to think about it.
