front disc brake hoses #2631415
03/11/19 12:07 PM
03/11/19 12:07 PM
O
otter440 Offline OP
otter440  Offline OP
O
What hoses do i use when putting 1970 front disc brake setup on a 1966 coronet thanks using 1968 style sway bar
Re: front disc brake hoses [Re: otter440] #2631591
03/11/19 08:56 PM
03/11/19 08:56 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You are probably going to have to use the brake hoses that connect to the disc brake calipers. The drum brake hoses likely won't connect to the calipers. If there is interference between the sway bar and the hoses, you will be way ahead if you modify the mounting brackets for the sway bar and keep the hoses that match the calipers. Gene
Re: front disc brake hoses [Re: poorboy] #2631624
03/11/19 10:40 PM
03/11/19 10:40 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Ask Dr. Diff . . . Cass has all that figured out . . and he could supply hoses if needed
