2004 DR dead door #2631098
03/10/19 02:08 PM
03/10/19 02:08 PM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
Hey guys! The driver side, rear door on my pickup went slowly dead. It started when the key fob wouldn't activate that lock. Then about a year later the window doesn't go up and down, now it's lost the stereo speaker. Anyone have any experience with this? Thanks!
Re: 2004 DR dead door [Re: Dave Hall] #2631104
03/10/19 02:20 PM
03/10/19 02:20 PM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
possibly a wire is cut/broken. have seen that b4. power/ground wire in rubber tubing.
Re: 2004 DR dead door [Re: rbkt65] #2631129
03/10/19 03:37 PM
03/10/19 03:37 PM
Cotati, CA
Cotati, CA
That's what I was thinking. Certainly easier than a BCM issue. Those little accordion rubber tubes are tough!
Re: 2004 DR dead door [Re: Dave Hall] #2631206
03/10/19 08:24 PM
03/10/19 08:24 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Wires are broken in the rubber boot.
My 2002 started doing it in 2010, by the end of 2012 only the window still worked, pulled back the rubber boot from the hinge pillar and sure enough most of the wires were severed, the window ones were about half way severed. I ended up drilling out the connector shell but keeping them as that is what retains the boot to the hinge pillar and feeding new wire through the pillar-boot-door and re-terminating with a new connector on either end using a much more flexible type of wire vs the regular PVC insulated wire originally installed. This was all before the Dorman option existed, out of principle I refused to purchase a new harness from chrysler given the price and knowing it would fail again.
Re: 2004 DR dead door [Re: 135sohc] #2631290
03/11/19 12:50 AM
03/11/19 12:50 AM
Cotati, CA
Cotati, CA
135! Thanks man! That looks totally easy with the Dorman fix!
Re: 2004 DR dead door [Re: Dave Hall] #2632397
03/13/19 07:33 PM
03/13/19 07:33 PM
Cotati, CA
Cotati, CA
Just found it for $112 on Amazon.
Re: 2004 DR dead door [Re: Dave Hall] #2632638
03/14/19 01:11 PM
03/14/19 01:11 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
$98 on Rockauto plus we get %5 off that. Shipping is about $8 so it runs just about $101.10...
Hey, ten bucks is ten bucks!
Re: 2004 DR dead door [Re: Dave Hall] #2632658
03/14/19 01:41 PM
03/14/19 01:41 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Oh crap. Thanks for the post.
My '03 has exactly the same issue, with the same door, started the same way, same same same. I have been putting off looking at it.
I'm glad I stumbled upon this.
Now I have to figure out what the difference is between '03 and '04.
Rich H.
Esse Quam Videri
Re: 2004 DR dead door [Re: ZIPPY] #2632738
03/14/19 06:14 PM
03/14/19 06:14 PM
Cotati, CA
Cotati, CA
Thanks Jwilli500! I'll check it out!
