Re: Vin question
[Re: fastmark]
#2630918
03/09/19 09:50 PM
03/09/19 09:50 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
The Automotive plant assigns the number to a body. So the B is the plant in the serial number 123456 would only be the assigned number. All other numbers and letters tell about the body and the motor and year.
1971 HEMI E BODY REGISTRY
Re: Vin question
[Re: 6bblgt]
#2630965
03/10/19 01:21 AM
03/10/19 01:21 AM
Posts: 21,514 N.E. OHIO, USA
A12
N.E. OHIO, USA
there should be ONLY one "0B123456", but mistakes happen Is it possible to have?: 0A123456
0B123456
0E123456
0G123456
Re: Vin question
[Re: Alaskan_TA]
#2631009
03/10/19 09:47 AM
03/10/19 09:47 AM
Posts: 6,407 Abilene, Texas
fastmark
Abilene, Texas
Typos are fairly common.
What have you found here? Well, I’ll tell you, Barry. But you have to promise me you won’t publish this vin number, turn it over to the FBI, CIA,ATF, DEA, SS, IRS,or the KKK. LOL! Seriously, I have a customer that bought a 70 RR at an auction. She has lots of cars, but this is her favorite. It’s a real FC7, white int, 383, 4 speed with a Air grabber. She had some electrical problems that were fixed poorly, an overhaul done but a local hack mechanic and some other poorly done work. It’s a fairly nice showing car with some minor rust coming back , but a fun driver. She is most proud of the fact it is “ matching numbers” and mentioned it constantly. Well, I put it on the lift and found all the mechanical problems and found the numbers on the trans that matched the vin but when I looked at the motor, it was stamped with the correct numbers but the plant code was a B instead of the G it should be. It was oblivious to me right off that the fonts were incorrect and someone had milled the pad and restamped the block. I guess they were not used to faking St. Louis cars and did not have G stamp. Lol! Anyway, she was heartbroken. You would have thought I’d just ran over her dog or something. I assured her the car was real ,but it was obvious to me it had been raced and the motor replaced at some time. This misconception that the Chevy people have created that if it’s not “matching number” it’s not a real car is ridiculous. Most people don’t even know the difference or how to tell. I gave up with local car shows people asking if my AAR is matching numbers or “does it have a Hemi in it” questions. I just says yes, anymore. Anyway, this leads me to thinking about some of the 4 speeds I have collected. Since they are only stamped with the partial vin how could you tell exactly which ONE car they came out of. Could it be a possiblility they may “ match “ more than one car? Guess I need to list all the ones I have so we can investigate.
Re: Vin question
[Re: fastmark]
#2631086
03/10/19 01:26 PM
03/10/19 01:26 PM
Posts: 1,326 VA
dragon slayer
VA
Trans would only match one year like motor since trans stamped with year, plant and serial #. So 0Gxxxxxx as example for her car
Re: Vin question
[Re: Alaskan_TA]
#2631095
03/10/19 02:05 PM
03/10/19 02:05 PM
fastmark
Abilene, Texas
In any case, that one trans could only match one car, correct? You would have to have the complete known vin from the car and THEN find the trans to match. Finding the trans first and you would still have to guess somewhat. A couple of mine are just empty cases I have obtained through the years.
Re: Vin question
[Re: Alaskan_TA]
#2631113
03/10/19 02:45 PM
03/10/19 02:45 PM
hemicar1971
Chicago Blackhawks
This is one reason why a lot of us collect information. Some have lists of motor and transmission, broadcast sheets and of people that have pieces from a certain body. Many of us have united these kinds of parts with the owners of the body or vehicle. Barry has a vast amount or this information on 1970 Vehicles. At times we all ask each other if we know about a certain car to reunite a piece with the owner of a vehicle.
As for this serial number you are asking about. I would have the owner or lady do some leg work with previous owners and try to trace back and ask those people involve what might of happened. Were I worked in an Automotive plant the same stamping tool was used to stamp the block and the transmission. If this was done in all Chrysler Plants then the stamp on the motor should be the same as on the transmission, With a serial number example 0B123456 you would only have to move the numbers and only a few numbers going from one vehicle to another at most times. The 0 is for the year and would never change, the B is for the plant and also should never be removed or changed in the stamp only the numbers would vary to the next bodies serial number.
Re: Vin question
[Re: Alaskan_TA]
#2631152
03/10/19 05:13 PM
03/10/19 05:13 PM
Posts: 2,361 PA
70HemiGTX
PA
What have you found here? My car's body stampings are off by 10,000 from all the other things I have with #'s on them. The dash tag, the driver's door tag, and what's left of the broadcast sheet all match each other. (10,000 less than the body stampings.) I do not have the original block or trans, so I do not know what was stamped on those. I'm assuming it probably would be consistent with the body stampings??? Maybe I'm wrong. Were the engine, trans., and body all stamped at the same time or were they stamped at different times?
Re: Vin question
[Re: hemicar1971]
#2631173
03/10/19 06:38 PM
03/10/19 06:38 PM
fastmark
Abilene, Texas
As for this serial number you are asking about. I would have the owner or lady do some leg work with previous owners and try to trace back and ask those people involve what might of happened. Were I worked in an Automotive plant the same stamping tool was used to stamp the block and the transmission. If this was done in all Chrysler Plants then the stamp on the motor should be the same as on the transmission, With a serial number example 0B123456 you would only have to move the numbers and only a few numbers going from one vehicle to another at most times. The 0 is for the year and would never change, the B is for the plant and also should never be removed or changed in the stamp only the numbers would vary to the next bodies serial number. It was bought at an auction so previous owners are not available, probably on purpose. Looking at the stamps, they are obvious hardware store stamps. I told her to drive it and have fun.
