Converter slippage... #2630834
03/09/19 05:30 PM
03/09/19 05:30 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
There a way to figure the converter slippage...
Some say slippage can add 300 to 500 rpm or more.
Logically the slippage must be more at full throttle than cruising speed.
By the way I use B&M 10415 Holeshot 2400 Stall.
Re: Converter slippage... [Re: STROKIE] #2630835
03/09/19 05:40 PM
03/09/19 05:40 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Tire size - gear ratio - MPH - RPM. If you know three, you can figure the forth. Typically trap speed at the track is used with the car under power. However much more the RPM is than what the formula says it should be, is how much slippage there is.
Re: Converter slippage... [Re: STROKIE] #2630884
03/09/19 08:05 PM
03/09/19 08:05 PM
Cab_Burge Online work
Cab_Burge  Online Work
A good street and strip converter will drive like a stock converter at light part throttle driving and then slip if you go to WOT below the stall speed, it should lock up and have less than 10% slippage at or above the stall speed, especially in high gear above 5000 RPM
Measure the circumference of both rear tires and inflate them so they are within 1/4 inch of each other on the circumference and then do the math for your RPM at the finish line in the 1/8 or 1/4 mile and see how much more or less your calculations show.
IE if you see 6600 RPM in high gear in the 1/4 mile and your calculations how 125 MPH and your time slips says 120.0 MPH your doing good, if it shows 125 MPH and your time slips says 105 MPH your not doing so good.
Anything more than 10% is not good, less is better.
Re: Converter slippage... [Re: Cab_Burge] #2631178
03/10/19 07:01 PM
03/10/19 07:01 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
How can I figure the RPM at the 1/4 mile finish line.
I went to the the track a few times but I don't to know exactly the rpm at the finish line... shruggy
Re: Converter slippage... [Re: STROKIE] #2631183
03/10/19 07:11 PM
03/10/19 07:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Here you go.
Doug
http://www.wallaceracing.com/mobile/converter-slip.php
Re: Converter slippage... [Re: STROKIE] #2631204
03/10/19 08:16 PM
03/10/19 08:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If you experience 10% slippage for any significant length of time, you'll know about it.
Your transmission will spout flames.
Boffin Emeritus
Re: Converter slippage... [Re: STROKIE] #2631221
03/10/19 09:09 PM
03/10/19 09:09 PM
You need to watch a good tach at the finish line and use that for your calculations and use the calculator to figure the calculated MPH with your RPM, gears and tire sizes and then use your MPH to figure how much differences you have between the calculated MPH and your actual MPH.
Not all tach are as good as the better ones so choose quality over cheaper prices on buying your tach
BTW, I've seen and race with good race converters that slip over 10 % in the 1/4 mile, a really good one will slip around 2 to 5% at the finish line.
