U-joint Girdle #2630434
03/08/19 04:03 PM
03/08/19 04:03 PM
Penna
70satelliteguy Offline OP
Penna
The Rear u-joint clamps on my Dana 60 from Strange are getting old and rusty on my racecar and I was thinking about replacing them . Has anyone used any of the u-joint Girdles from Jeg's or Summit?
Thanks mIke
Re: U-joint Girdle [Re: 70satelliteguy] #2630436
03/08/19 04:08 PM
03/08/19 04:08 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
if youre referring to the billet aluminium units, i tried them on my 8 3/4, wasn't a great success, managed to break one somehow. bought the steel U bolts after that.
Re: U-joint Girdle [Re: rebel] #2630445
03/08/19 04:26 PM
03/08/19 04:26 PM
Locomotion Offline
Locomotion  Offline
IMO, the best yokes are billet or machined steel versions with u-bolts. OEM type yokes can eventually spread over time regardless of "girdles" or other band-aids. I also use Spicer solid u-joints.
There are some manufacturers who also make them for other Mopar joints - 7260, 1350, etc. Shop around for better price. At work and don't have info handy.
7290 yoke
Re: U-joint Girdle [Re: Locomotion] #2630453
03/08/19 04:34 PM
03/08/19 04:34 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yeah they work great if you never use them ..........
Re: U-joint Girdle [Re: DoubleD] #2630493
03/08/19 06:33 PM
03/08/19 06:33 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Small bolts are the weak link.
Re: U-joint Girdle [Re: CMcAllister] #2630521
03/08/19 07:44 PM
03/08/19 07:44 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I also broke a set running 10.90's at 3500 lbs.
Re: U-joint Girdle [Re: Locomotion] #2630537
03/08/19 08:26 PM
03/08/19 08:26 PM
Alberta
440_Offroader Offline
Alberta
7290 yoke
I agree with this... In the 4x4 world, u-bolts are a much better way to hold your u-joint to the yoke...
Re: U-joint Girdle [Re: 440_Offroader] #2630544
03/08/19 08:48 PM
03/08/19 08:48 PM
P
Porter67 Offline
Porter67  Offline
P
Ive had no issues with the HD U bolt looking units on a S60 from Dr Diff running a heavy car going 9.40-s with a manual trans.
Re: U-joint Girdle [Re: 70satelliteguy] #2630548
03/08/19 08:53 PM
03/08/19 08:53 PM
Penna
Penna
This is a Dana I purchased directly from Strange years ago. It has the SOLID 1350 u-joints. I just had both front and rear 1350's replaced since they are about 15 years old with almost 1000 or so flawless passes. I think you talked me out of using the Girdle type .
Where can I get a suitable replacement for the U bolt type I have other than calling Strange?
Thanks mIke
Re: U-joint Girdle [Re: 70satelliteguy] #2630565
03/08/19 09:33 PM
03/08/19 09:33 PM
P
Porter67 Offline
Porter67  Offline
P
https://www.ebay.com/itm/Moroso-85080-Heavy-Duty-U-Joint-Straps-Dana-60/312019239015?epid=28017011380&hash=item48a5cbc067:m:m0cotSs9kpBcNn6JghLmiRQ
Dr Diff dont list them separate but might sell them? They might be a little different then the Moroso units.
https://www.doctordiff.com/1350-u-bolt-pinion-yoke-package.html
Re: U-joint Girdle [Re: 70satelliteguy] #2630570
03/08/19 09:42 PM
03/08/19 09:42 PM
Locomotion Offline
Locomotion  Offline
$142.00
PN : U1598
Dana 60 yoke / 1350 / Strange chrome moly
This Strange part looks good. Summit has them too.
A&A Transmission has billet units, like I originally mentioned, but are more expensive.
A&A billet 1350 yoke.
Re: U-joint Girdle [Re: Locomotion] #2630699
03/09/19 11:29 AM
03/09/19 11:29 AM
Penna
Penna
Thanks for the help. I just ordered the Moroso part.
Mike
Re: U-joint Girdle [Re: 70satelliteguy] #2630708
03/09/19 11:38 AM
03/09/19 11:38 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
If the car is set up right it doesn’t take much to hold the rear u-joint in place. I’m sure an Engineer or someone smarter than I am could word it better but the saddle holds the u-joins in place and does most of the work. My Duster goes 1.25 in the 60 foot and I have the cheap factory straps and 5/16 bolts on my stock Dana yoke.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: U-joint Girdle [Re: pittsburghracer] #2630720
03/09/19 12:06 PM
03/09/19 12:06 PM
Locomotion Offline
Locomotion  Offline
If the yoke itself spread over time, it won't matter what kind of straps or bolts are used. It may not happen often, but eventually can. It did to me after many years of running a 3,540+ lb car. Like the argument against 8 3/4" rears in general, weight has a lot to do with it. If there's ever a hint of side-to-side movement of the u-joint in the yoke saddle as installed, it's junk. But I also tend to prefer parts with an extra safety margin.
Re: U-joint Girdle [Re: 70satelliteguy] #2630758
03/09/19 01:49 PM
03/09/19 01:49 PM
As already pointed out make sure your rear U joint you are using has to be shoved in hard, not slide in easily, and stay in the pinion yoke with no slop or looseness.
The straps are not meant to take any side load, they are meant to stop forward movement only.
Re: U-joint Girdle [Re: pittsburghracer] #2630779
03/09/19 02:32 PM
03/09/19 02:32 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This.
Anything more than a factory strap is just a fancy part looking for a problem that doesn't exist, IMO.
Re: U-joint Girdle [Re: BSB67] #2630784
03/09/19 02:40 PM
03/09/19 02:40 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
My experience with the girdles is all bad.
Ill fitting hunks of material that would have been better served being turned into beer cans.
This was in a 9 " , but they ( Moroso ) would not fit with out massaging.
I was working at a machine shop at the time , so I figured I would modify their design and eliminate the problems I encountered.
I came up with smaller hunks of crap is all.
Like has been stated above , the strap or U bolt is plenty.
Re: U-joint Girdle [Re: tubtar] #2631112
03/10/19 02:43 PM
03/10/19 02:43 PM
Penna
Penna
No sideways movement guy's. Just replaced the 1350's so I thought I would replace the u bolt as well.
Thanks Mike
Re: U-joint Girdle [Re: 70satelliteguy] #2631153
03/10/19 05:13 PM
03/10/19 05:13 PM
Thanks Mike
When in doubt on race parts change them parts out!
Good call on PMing the U joint but please don't try using a girdle of any type, the stock U bolts are plenty strong to hold the cups firmly into the yoke.
Re: U-joint Girdle [Re: Cab_Burge] #2631288
03/11/19 12:44 AM
03/11/19 12:44 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I thought I would try the good aluminum ones. Made about a 80 ft pass and got towed to the pits after launching the Challenger. Should of just left the original strap type on that never ever failed for years and years. Listen the all the guys and pick what they have had success with. It is a pain to try to get those bolts out of the yoke after being sheared off and next to impossible at the track without a lot of help. Also some one said about using the solid U joint that is a good choice.
1971 HEMI E BODY REGISTRY
