440 sixpack #2630477
03/08/19 05:50 PM
03/08/19 05:50 PM
ut
ljp Offline OP
ljp  Offline OP
ut
how can you identify a real sixpack block. thanks
Re: 440 sixpack [Re: ljp] #2630491
03/08/19 06:28 PM
03/08/19 06:28 PM
Cab_Burge Online work
Cab_Burge  Online Work
What year are you asking about ?
Re: 440 sixpack [Re: Cab_Burge] #2630519
03/08/19 07:43 PM
03/08/19 07:43 PM
Ohio
P
PDR Dude Offline
PDR Dude  Offline
P
Ohio
This question has been a topic on the board many times before....Apparently you need a vin. stamped block with a V engine code in the stamping. Others will chime in shortly,,
Re: 440 sixpack [Re: ljp] #2630524
03/08/19 07:52 PM
03/08/19 07:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
No such thing as a 'sixpack' block.
The 340 version TA block leftovers were used on 4-barrel cars at times.
440-4 or 440-6 - same casting number though.
So for a 440, you have to match the partial VIN to a car with a legitimate 440-6 VIN.
Re: 440 sixpack [Re: Alaskan_TA] #2631915
03/12/19 02:33 PM
03/12/19 02:33 PM
Chicago
PurpleBeeper Offline
Chicago
I agree 100% with Alaskan T/A. You'd need to take the sequence number off the block & match that up with the complete VIN number from a V-code car. You might get lucky with someone who does Mopar research and has huge lists of VIN numbers to match up with an original block. Having said all that, the blocks are IDENTICAL to non six pack blocks.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 440 sixpack [Re: PurpleBeeper] #2634158
03/18/19 07:23 PM
03/18/19 07:23 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
For starters it would have be an E-F or G 440 HP block & have the partial vin# of a V code car stamped in it,but lets say the supposed 440-6 block came out of a 71 Jensen Interceptor SP that wouldn't have a vin# stamped into it then what,if its just a bare block you would never be able to tell the difference, if its a complete bottom end that's never been rebuilt you could determine if its a SP eng.by the specific SP internal components & that's about it,there was about 200 Jensen SPs made so there could be some engines around.
