Hemi Dart k frame spacers #2629721
03/06/19 07:06 PM
03/06/19 07:06 PM
Howell, Michigan
Hemidavey Offline OP
Howell, Michigan
Why did the engineers use 1/2" spacers to lower the K frame on Hemi Darts?
Re: Hemi Dart k frame spacers [Re: Hemidavey] #2629726
03/06/19 07:19 PM
03/06/19 07:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
To fit the thing under the hood & gain clearance for valve covers & headers.
I thought it was actually 1".
The spacers then created some handling issues...covered in some stories I've read from the guys who worked on them.
Re: Hemi Dart k frame spacers [Re: topside] #2629769
03/06/19 09:04 PM
03/06/19 09:04 PM
Howell, Michigan
Howell, Michigan
They used 1/2” flat bar stock , sheered off and punched the holes.
It did cause a handling issue (bump steer) so they bent the arm on the lower ball joint to correct it, once they figured it fixed the problem, then sent out specially made lower ball joints to the car owners.
Re: Hemi Dart k frame spacers [Re: Hemidavey] #2630067
03/07/19 05:57 PM
03/07/19 05:57 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I thought they were 1/4" (but it's been a long time). Some of the books would tell. The way I remember it was for carb to hood clearance.
2011 Drag Pak Challenger
Re: Hemi Dart k frame spacers [Re: rickseeman] #2632464
03/13/19 10:26 PM
03/13/19 10:26 PM
Howell, Michigan
Howell, Michigan
