Best Battery picks for a daily driver? #2629445
03/05/19 11:56 PM
03/05/19 11:56 PM
fullmetaljacket Offline OP
Which battery out there in the open market has a good CCA and durability rating?
I'm looking for a good battery for one of my daily drivers.
Exide, Diehard, etc.
Re: Best Battery picks for a daily driver? [Re: fullmetaljacket] #2629467
03/06/19 12:57 AM
03/06/19 12:57 AM
Maryland
MoparMike1974 Offline
Maryland
I only use Deka batteries. I get 5-7 years out of them on average. I also run them in all the equipment at work, we have 28 in service at the moment.
Re: Best Battery picks for a daily driver? [Re: MoparMike1974] #2629475
03/06/19 01:32 AM
03/06/19 01:32 AM
WA
tman Offline
tman  Offline
WA
Our local Costco sells Interstate batteries. Interstate is a reliable brand.
Re: Best Battery picks for a daily driver? [Re: tman] #2629477
03/06/19 01:48 AM
03/06/19 01:48 AM
Kirkland, Washington
Pacnorthcuda Offline
My last 5 or 6 DD batts have been Costco Kirkland Signature (JC) and they've been fine, but I now longer shop there (moved) so I am about to try Walmart ...also Johnson Control batts.
Re: Best Battery picks for a daily driver? [Re: Pacnorthcuda] #2629488
03/06/19 04:32 AM
03/06/19 04:32 AM
WA
tman Offline
tman  Offline
WA
Costco stopped selling Signature brand several yrs ago. Its Interstate now in Seattle area.
Re: Best Battery picks for a daily driver? [Re: tman] #2629497
03/06/19 08:12 AM
03/06/19 08:12 AM
Thank you guys.
Re: Best Battery picks for a daily driver? [Re: fullmetaljacket] #2629511
03/06/19 09:22 AM
03/06/19 09:22 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A observation i have seen over the years, the worst use of a battery is infrequent use. Lett me be clear, meaning if its seldom used, it will not last, ie buy a cheap a battery, if its used daily, buy a cheap battery, it will last a long time. Expensive batteries are best make to make one feel good. biggrin
Re: Best Battery picks for a daily driver? [Re: jcc] #2629521
03/06/19 10:08 AM
03/06/19 10:08 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Most companies have a cheaper line and a more expensive line. At least with Interstate and Decca, the cheaper ones of the same size weigh less. work
Re: Best Battery picks for a daily driver? [Re: Mattax] #2629544
03/06/19 10:40 AM
03/06/19 10:40 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Around here NAPA has the better prices and comparable warranties.
Don't be the exception.
Re: Best Battery picks for a daily driver? [Re: Supercuda] #2629566
03/06/19 11:10 AM
03/06/19 11:10 AM
Costco used to have a Killer non-prorated warrantee but apparently that's gone now with the switch to Interstate.
Not Interstates fault--I think they realized the previous warrantee was VERY expensive for them (I used it once).
I remember back in the 90's when Interstate was THE brand, but like a lot of things, that is no longer the case.
The cheaper batts are far better than they used to be, and the greats (Interstate and the Diehards) are no longer.
And yeah...very few actual mfgers.........East Penn, Johnson Controls, Exide and I think one other make up 99 percent of the brands out there.
....and if you think about that,,,,, It means the good AND the bad batts were all made by the same people, but now the bad are better, and the good not AS good. Hmmmmmmmm. Could it be a trickle down on manufacturing technology? The batt mfgers discovered that is cheaper in the long run to use GOOD mfg methods for all their lines, cheap-to-expensive?
True for all sorts of industries.
Re: Best Battery picks for a daily driver? [Re: Pacnorthcuda] #2629636
03/06/19 01:44 PM
03/06/19 01:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Pretty much Advance batterys in ours.We used them a lot at the last 2 shops I was at.My son is parts pro so we also get a discount even now after I retired.Never had a problem with them.Had one Ford type in one tractor we had and it was like 12 years old whe we sold it and still started it.Rocky
Chrysler Firepower
Re: Best Battery picks for a daily driver? [Re: fullmetaljacket] #2629674
03/06/19 02:54 PM
03/06/19 02:54 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I picked up a Interstate for SK Lee at my Costco, think I have 2 Kirkland’s(old Costco not sold anymore) and a interstate in my family vehicles...
Re: Best Battery picks for a daily driver? [Re: fullmetaljacket] #2629683
03/06/19 05:28 PM
03/06/19 05:28 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
I would say an AGM battery. Given the nature of the electrical systems, and how much the average hobby car sits, you'll get rid of the vented battery gas under your hood eating away at finish, wiring, etc. I run a Duralast Platinum. With the always available Advance Auto online coupons, they can be had for 160 or so, a fair bit less than an Optima or other equivalent.
Re: Best Battery picks for a daily driver? [Re: BcudaChris] #2629798
03/06/19 10:09 PM
03/06/19 10:09 PM
5thAve Offline
5thAve  Offline
The last interstate batteries I bought were junk that didn't last more then a few years.
The Costco batteries I gave up on after having to replace them every year because of dead cells.
I've had some luck with Delco batteries but last year I bought a couple batteries from a local place and a couple walmart batteries and will see how those do.
Re: Best Battery picks for a daily driver? [Re: 5thAve] #2629868
03/07/19 07:51 AM
03/07/19 07:51 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I've had good luck with Autozone's Duralast Gold lately.
Re: Best Battery picks for a daily driver? [Re: Mr340] #2629876
03/07/19 08:40 AM
03/07/19 08:40 AM
Bradenton, Fl 34203
Kilroy was here Offline
Bradenton, Fl 34203
Interstate used to be the battery to buy. My last one lasted 2 years and 2 months just out of the warranty. I have a friend for 20 years who runs a shop and he's going to stop carrying Interstate because too many of come back. My current 1970 Dodge an Optima. No issues approximately 4 years old. If it goes south, I will either by another Optima, which are pricey but work well. Or AutoZone with a 3-year full warranty after that is prorated.
Re: Best Battery picks for a daily driver? [Re: Kilroy was here] #2629928
03/07/19 11:39 AM
03/07/19 11:39 AM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Costco does sell INTERSTATE but in my local Costco here in VA they sell a lower grade battery and do not stock on for my 71 Challenger. I got one from the Interstate Battery WHSE ..they are usually not that far away and was cheaper if you go pick it up there. The higher grade battery for my car was all black case, not the white with greentop .
Re: Best Battery picks for a daily driver? [Re: THESHAKERPROJECT] #2629940
03/07/19 11:57 AM
03/07/19 11:57 AM
Findlay
Ramman Offline
Ramman  Offline
Findlay
I don't know about "Best" but I've had the best "Luck" with the last three I bought were Wal-Mart middle level EverStart units.
Re: Best Battery picks for a daily driver? [Re: Mr340] #2629941
03/07/19 11:59 AM
03/07/19 11:59 AM
SW CO
HemiSportFury Offline
SW CO
Same here. Getting very good life out of them.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: Best Battery picks for a daily driver? [Re: HemiSportFury] #2629945
03/07/19 12:10 PM
03/07/19 12:10 PM
KY
65pacecar Offline
65pacecar  Offline
KY
Ive been using the AGM batteries from Sams Club, had great luck with them so far.
