where to find water pump housing bolts? #2629368
03/05/19 08:53 PM
03/05/19 08:53 PM
MO
69 bee Offline OP
69 bee  Offline OP
MO
I'm looking to purchase the long water pump housing bolts for a 383 which go through the tensioner used on an AC car. Bolts are like 5 1/4? long 3/8 x 16. Does anyone know where I can find quality bolts for this application? I bought a bolt set but they do not come with the longer ones used on the tensioner.
Any ideas appreciated. Thanks
Re: where to find water pump housing bolts? [Re: 69 bee] #2629374
03/05/19 09:01 PM
03/05/19 09:01 PM
70duster340 Offline
70duster340  Offline
I would suggest a place like Home Depot or Lowe's. I have been lucky locating hard to find bolts there. It may take some searching through their selection, but it's definitely possible.
Re: where to find water pump housing bolts? [Re: 70duster340] #2629379
03/05/19 09:18 PM
03/05/19 09:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Tractor Supply or Ace Hardware
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: where to find water pump housing bolts? [Re: pittsburghracer] #2629384
03/05/19 09:34 PM
03/05/19 09:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Fastenal
Re: where to find water pump housing bolts? [Re: 69 bee] #2629398
03/05/19 09:55 PM
03/05/19 09:55 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Mcmaster-Carr 91257A645
Re: where to find water pump housing bolts? [Re: 69 bee] #2629400
03/05/19 10:03 PM
03/05/19 10:03 PM
tucson az
frank Offline
frank  Offline
tucson az
Ace Hardware will have it
Re: where to find water pump housing bolts? [Re: frank] #2629410
03/05/19 10:31 PM
03/05/19 10:31 PM
MO
69 bee Offline OP
69 bee  Offline OP
MO
Should i go with grade 8?
Re: where to find water pump housing bolts? [Re: 69 bee] #2629414
03/05/19 10:44 PM
03/05/19 10:44 PM
PA.
"Little"John
"Little"John
PA.
Heck ya for the money difference
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: where to find water pump housing bolts? [Re: 69 bee] #2629425
03/05/19 11:08 PM
03/05/19 11:08 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
No.
To get proper stretch of the bolt, you want to torque the bolt to 75% of proof yield (follow the torque charts). Cast iron can't handle grade 8 torque.
Re: where to find water pump housing bolts? [Re: markz528] #2629434
03/05/19 11:39 PM
03/05/19 11:39 PM
PA.
"Little"John
"Little"John
PA.
No.
You do know that a lot of the factory bolts were graded bolts right. LOL. Give me a break.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: where to find water pump housing bolts? [Re: 69 bee] #2629443
03/05/19 11:55 PM
03/05/19 11:55 PM
Cab_Burge Online work
Cab_Burge  Online Work
NO!
No need to buy that quality bolt that is only holding those brackets in compression.
Re: where to find water pump housing bolts? [Re: pittsburghracer] #2629447
03/05/19 11:57 PM
03/05/19 11:57 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by pittsburghracer
[quote=markz528][quote=69 bee]
Into cast iron???? Which ones????
You don't use grade 8 bolts into cast iron per all the fastener training I have been through. You want to do it, that's fine, but don't give the OP bad advice.. I prefer to to use precision practices with everything I do (including using proper hardware) and it has served me very well in life...............
Re: where to find water pump housing bolts? [Re: markz528] #2629454
03/06/19 12:07 AM
03/06/19 12:07 AM
PA.
"Little"John
"Little"John
PA.
I see you are an Engineer. LOL. I worked for a lot of them in the steel mill. I'll be checking my engine bolt box tomorrow to check grade markings. And Cab please tell me a few extra quarters are going to break the bank. I prefer to use studs where possible but those are even MORE expensive.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: where to find water pump housing bolts? [Re: markz528] #2629462
03/06/19 12:38 AM
03/06/19 12:38 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Grade 8 used for head bolts, main bolts, intake bolts, and the alternator bolt that goes in the head, on big blocks. Waterpump housing bolts are grade 5. That idler has a cast spacer that goes behind it, grade 5 with hard washers for that if memory is right.
Re: where to find water pump housing bolts? [Re: 4406bbl] #2629463
03/06/19 12:51 AM
03/06/19 12:51 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
If you want the correct oem style bolt AMK should have them, $30 minimum. Partsmix on ebay, or megaparts may have them. Try AMK B-11455, or b11456.
Re: where to find water pump housing bolts? [Re: 4406bbl] #2629470
03/06/19 01:03 AM
03/06/19 01:03 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
grade 8!!!
my ladder of success is missing some rungs
Re: where to find water pump housing bolts? [Re: pittsburghracer] #2629484
03/06/19 02:53 AM
03/06/19 02:53 AM
.25 here and a few more .25 later adds to dollars peer week, pretty soon you have wasted hundred of dollars per year(where is the shruggy IMOGI?
Re: where to find water pump housing bolts? [Re: 69 bee] #2629495
03/06/19 08:01 AM
03/06/19 08:01 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Grade 5 or A307 if you find them in the proper size will be fine. Grade 8 or A325 is overkill for the low tension application.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: where to find water pump housing bolts? [Re: Cab_Burge] #2629496
03/06/19 08:02 AM
03/06/19 08:02 AM
PA.
"Little"John
"Little"John
PA.
During my 33 years of Millwright work we had our nuts bolts and washers delivered by a big name outfit. The quality of those bolts changes so much over the years that when we were taking apart machinery if it was a thru bolt with a nut on it we where better off just grabbing a burning outfit and burning them off. The materials had gotten so cheap and the last breads were so crude that when we hit them with an impact they were not going to be reusable anyway. If you want to use cheap imported junk go right ahead but for me I with spend a little more per bolt to use a better quality imported by lt. Goodluck and I can tell you one good think about the cheap stuff. When they snap off they are easier to drill for the easy out. Lol 😂 And yes when our Engineers came out of College they thought perfect World senerio until we showed them we always didn’t work in the perfect world.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: where to find water pump housing bolts? [Re: pittsburghracer] #2629548
03/06/19 10:44 AM
03/06/19 10:44 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hmm, a thoughtful well reasoned explanation as to why not to use a grade 8 bolt vs a hack with a gas axe whi totally changed the issue from grade 5 vs 8 to "if you want to use cheap imported junk"
I see why the US steel industry practically fell thru it's ass.
Don't be the exception.
