Re: one piece pan gasket for small block
[Re: kbcuda]
#2628783
03/04/19 05:45 PM
03/04/19 05:45 PM
Andrewh
it won't work. 2 reasons it doesn't work. magnum engines all use the 360 size seals. 5.2 or 5.9 are the same pan and gasket.
but even if you got it to seal, there is a lot of gap to seal. Feets will tell you I am an RTV fiend. I will use a whole tube of the stuff on each side. I used it on a 360 pan for a 5.9 and it still will pour oil out of the front and back.
I haven't looked in a while. but they did make a 1 piece for sb a while back. for the la type engines.
[Re: Andrewh]
#2628789
03/04/19 05:57 PM
03/04/19 05:57 PM
Posts: 20,551 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I have one, it's orange in color, on an LA 360 block and not a 318. I can'r remember where I bought it from! If it comes to me I'll post it. Edit: Milodon versions on Ebay, but it doesn't specify if it's a 318/340 or 360 style.
[Re: mopars4ever]
#2628877
03/04/19 09:58 PM
03/04/19 09:58 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Read teh reviews "This is a one piece oil pan gasket designed to fit a Magnum style oil pan. It does not properly fit an LA style oil pan due to the notches in the front of the oil pan."
[Re: kbcuda]
#2628892
03/04/19 10:44 PM
03/04/19 10:44 PM
Posts: 13,585 md
mopars4ever
md
Read teh reviews
Did you let Jegs know?
[Re: kbcuda]
#2628895
03/04/19 10:56 PM
03/04/19 10:56 PM
Supercuda
About to go away
About to go away
up yours
I didn't write the review and I have zero experience with it.
[Re: Supercuda]
#2628971
03/05/19 01:48 AM
03/05/19 01:48 AM
RapidRobert
no info on the subject at hand but I just had an issue with the front gasket for the half moon (under the tcover) on a speedway mtrs new pan so be sure & mockup/check fitment as needed before you breakout the cement. the 2 different sized holes (on each end) in the pan for the nubs to be pulled into need slight enlargeing with a drill (no big deal) but another thing to check if needed in your deal. If the 1 piece dont fit or another 1 piece doesn't fit I would go with regular gaskets (& be sure to check pan bolt hole flatness). I dont care for cork but not sure what is out there. EDIT & on the cork you may need to cut the long length into several sections for the bolt holes to line up. MORE EDIT the pump to tcover gasket fits better flipped one way, mockup/flip it dry on the pump & you will see the best way, that it covers quite a bit better.
