383 w/a.c. fan tensioner #2627320
02/28/19 11:45 PM
02/28/19 11:45 PM
MO
69 bee Offline OP
69 bee  Offline OP
MO
Does the bolt through the idler pulley come out? I have tapped on it and no luck. Let me know your thoughts as I'd like to replace the bolt with a new one but having trouble locating a bolt y kit which has it included. This is the bolt which the idler rotates on to tighten the belt.
I have the bracket and idler out of the block and on the bench, but the bolt appears to be held into the idler pulley bracket.
Re: 383 w/a.c. fan tensioner [Re: 69 bee] #2627468
03/01/19 12:44 PM
03/01/19 12:44 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Why do you want to replace the bolt. I think they are pressed into the bearing and a regular bolt will not work anyways. Check out this link.
https://www.manciniracing.com/baidpu.html
68 Charger R/T 440 auto
Re: 383 w/a.c. fan tensioner [Re: wesgtx440] #2627597
03/01/19 05:15 PM
03/01/19 05:15 PM
MO
69 bee Offline OP
69 bee  Offline OP
MO
Thanks for the reply. Not looking to replace the idler pulley or bolt joldiing pulley onto bracket. Looking to get the 5 1/2" bolt out of the bracket which goes through pump housing into block. I have the top one out which is the bolt which after tightening the belt is simxjed down. The bolt which allows the tension bracket to rotate is the one I'm trying to get out.
Re: 383 w/a.c. fan tensioner [Re: 69 bee] #2627610
03/01/19 05:49 PM
03/01/19 05:49 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
There shouldn’t be anything holding that bolt in? Maybe just crud buildup. Should come right out.
