Re: Body color or ?????
[Re: nobrakesneeded]
#2627003
02/28/19 05:25 AM
02/28/19 05:25 AM
Posts: 707 California
BigDaddy440
California
This may not be helpful as I don't have experience with the early 70s models, but in 68-69 for example, the undersides were primered a grayish color. The body color was feathered in on each side a bit beyond the rocker panels, but the majority of the underside was primered. This is how I did my 69 roadrunner, similar to factory.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2627026
02/28/19 11:12 AM
02/28/19 11:12 AM
Posts: 1,385 Az
69hemibeep
Az
Same way I did mine, overspray.
1969 Hemi Roadrunner 2nd owner
[Re: BigDaddy440]
#2627191
02/28/19 06:26 PM
02/28/19 06:26 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
This may not be helpful as I don't have experience with the early 70s models, but in 68-69 for example, the undersides were primered a grayish color. The body color was feathered in on each side a bit beyond the rocker panels, but the majority of the underside was primered. This is how I did my 69 roadrunner, similar to factory. More examples of how Lynch Road '69 B=bodies were underside color over sprayed with the bottom center dip gray (primer?) corrosion bath left unpainted body color. This is a low mileage survivor Super Bee, you can see the Bahama Yellow on the outside and the gray dip still inboard. There's more examples but can't get to them right now. I'd do a gray epoxy paint, not primer, then over spray it on the out side in body color if I was looking for O.E. but really I think it's best and less time and prep to just do the bottom body color and be done with it.
[Re: A12]
#2627248
02/28/19 09:36 PM
02/28/19 09:36 PM
Posts: 10,032 MN
JERICOGTX
MN
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2627259
02/28/19 09:52 PM
02/28/19 09:52 PM
A12
N.E. OHIO, USA
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look. I caught someone on their hands and knees looking under my '68 Road Runner for what I don't know but I said to him "hey if I hand you a wrench could you check a couple of muffler clamps for me while your down there" It was something stupid and if someone is checking out the underside of your car and they're not an OE judge then just ask them what they found so interesting and to also check a couple of muffler clamps too. Mike
[Re: JERICOGTX]
#2627316
02/28/19 11:36 PM
02/28/19 11:36 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look. Disagree. Instead paint it flat grey. Resto Rick sells a paint to do this. Then you have the protection of paint and the right look.
[Re: A12]
#2627329
02/28/19 11:54 PM
02/28/19 11:54 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look. I caught someone on their hands and knees looking under my '68 Road Runner for what I don't know but I said to him "hey if I hand you a wrench could you check a couple of muffler clamps for me while your down there" It was something stupid and if someone is checking out the underside of your car and they're not an OE judge then just ask them what they found so interesting and to also check a couple of muffler clamps too. Mike Some of these folks crack me up...had one call me out at a show...told me all 69 big block motors were orange.... "Uh...its a 68".... he scampered off.... lol
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
[Re: JMCFAN]
#2627333
03/01/19 12:14 AM
03/01/19 12:14 AM
Morty426
Sacramento CA
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look. I caught someone on their hands and knees looking under my '68 Road Runner for what I don't know but I said to him "hey if I hand you a wrench could you check a couple of muffler clamps for me while your down there" It was something stupid and if someone is checking out the underside of your car and they're not an OE judge then just ask them what they found so interesting and to also check a couple of muffler clamps too. Mike Some of these folks crack me up...had one call me out at a show...told me all 69 big block motors were orange.... "Uh...its a 68".... he scampered off.... lol Just ask "Where is your car, I would like to critique it?
[Re: JMCFAN]
#2627361
03/01/19 01:32 AM
03/01/19 01:32 AM
A12
N.E. OHIO, USA
Unless it's a 100% OE concourse restoration, that you want judged, I'd paint the entire underside body color. I know it's not correct, but the primer just looks like the painter didn't try. And the purists don't need to jump my comment, I know it's harder to replicate the OE look. I caught someone on their hands and knees looking under my '68 Road Runner for what I don't know but I said to him "hey if I hand you a wrench could you check a couple of muffler clamps for me while your down there" It was something stupid and if someone is checking out the underside of your car and they're not an OE judge then just ask them what they found so interesting and to also check a couple of muffler clamps too. Mike Some of these folks crack me up...had one call me out at a show...told me all 69 big block motors were orange.... "Uh...its a 68".... he scampered off.... lol I was selling my '68 Road Runner and got the same thing from a guy and his "Mopar Expert" too on the engine color being wrong. Got real cocky and wanted me to knock the price off by $5k or more for that mistake and the fact it may not even be a RR engine.........before I could say anything my friend (a real Mopar guy) said "you know it's a '68 and even if it were a '69 this ('68 RR) is an original A/C car and the '69 RR A/C engine it turquoise too. I had no interest in selling the RR to this guy even if he offered more then the asking price.
[Re: ct440rod]
#2627888
03/02/19 01:40 PM
03/02/19 01:40 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
You will only be here once so why would you do anything but restore it the way the factory did. Painting the undercarriage body color is as bad as painting the trunk with spatter paint or the engine compartment black. It's all WRONG! There are plenty of products that will protect and have the appearance of the original correct look from the factory. To the OP. If you have a GM guy restoring your Mopar you will have a ton of problems unless you watch him like a Hawk! Do your research and make him do it the way you want or on completion you will be disappointed.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: lewtot184]
#2628036
03/02/19 08:08 PM
03/02/19 08:08 PM
A12
N.E. OHIO, USA
I have a '65 coronet and a '69 coronet r/t. both have the original underbody paint. looks to be a flat black to me. both have some body color overspray showing. Wouldn't by chance both are LA assembly plant cars?
