68 Dart Biggest /Widest rear wheels and tire combo #2625624
02/24/19 09:44 PM
02/24/19 09:44 PM
Indiana
Tim8979 Offline OP
Tim8979  Offline OP
Indiana
Hi guys, I have a customer that wants the widest tires (like Drag Radials) and 8"- 10" wide 15" rims to go under a STOCK 68 Dart with 8.75. He does NOT want to mini tub or relocate the springs,but does plan to put SS springs on later he said. The car is not here to get measurements. You guys are always helpful and very knowledgeable, Greatly appreciate any info with tire sizes and offset/ backspace. Thanks in advance
Re: 68 Dart Biggest /Widest rear wheels and tire combo [Re: Tim8979] #2625643
02/24/19 10:08 PM
02/24/19 10:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
235/60-15 on a 15x7 wheel with 4-1/4" backspacing should fit without doing anything to the car. A wider tire may be possible, but then you may be looking at rolling or trimming the wheel opening lips etc.
SS springs may elevate the back of the car enough to get a 245/60-15 in there.
Re: 68 Dart Biggest /Widest rear wheels and tire combo [Re: Tim8979] #2625687
02/25/19 12:04 AM
02/25/19 12:04 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
My friend has 265-60-15 on 8 inch rims on his 69( not sure of offset),but with offset spring kit,you can go wider.
Re: 68 Dart Biggest /Widest rear wheels and tire combo [Re: Tim8979] #2625693
02/25/19 12:19 AM
02/25/19 12:19 AM
nj
JAMESDART Offline
JAMESDART  Offline
nj
255 60 15s fit without moving the springs
Re: 68 Dart Biggest /Widest rear wheels and tire combo [Re: JAMESDART] #2626086
02/25/19 10:31 PM
02/25/19 10:31 PM
blewbyu Offline
blewbyu  Offline
I second this
