Re: Pinto Duster steering part 2
[Re: MR_P_BODY]
#262525
03/25/09 07:29 PM
03/25/09 07:29 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Lengthen the steering arms 2", it wont hurt a thing and it actually helps, you dont want a fast reacting steering on the dragstrip. I had to lengthen mine on my last chassis
It wont really hurt anything really but it will shorten your turning radius. Id rather have that then the extreme angle you show now. mike
[Re: Sport440]
#262526
03/25/09 07:48 PM
03/25/09 07:48 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
It will swing to the rear of the car and if the rack arm is maxed out it will bend itself.
I admire what your doing but you need to put down the welder and do some more study. I dont have this rack thing down 100% myself.
Dont be like me and end up having to reposition your Rack 4 times.
I understand that it's not going to work how it is. Thats why I posted the pics. The rack has never been mounted yet. Just mocked up, so I can move it anywhere in needs to be. Where it is at right now it's pretty much right were it needs to be geometrically. All the pivots are in line and the rack is level across.
If the steering arms are extended 2" as Mr P suggested everything will be right on. I just don't know about welding cast to mild steel. Has anyone done this? I've welded cast to cast with ni-rod 55. But I dont know of a procedure for mild steel to cast.
[Re: MR_P_BODY]
#262528
03/25/09 07:59 PM
03/25/09 07:59 PM
DemonDust
Menomonee Falls
Use that same rod for cast to steel
I could also use nickel filler rod and tig weld it I believe. I'll have to give airgas a call tomorrow and see what they think is best.
What steel did you use? 1045?
[Re: DemonDust]
#262531
03/25/09 08:36 PM
03/25/09 08:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When you say you cut the taper off, what do you mean?
Where the tie rod end goes into, I used heim joints with a 7/16" or 1/2" bolt(I forget which it was) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#262532
03/25/09 08:40 PM
03/25/09 08:40 PM
DemonDust
Menomonee Falls
Oh ok. So you just drilled a .4375 or .500 hole in the end of the mild steel and run a bolt thru?
[Re: MR_P_BODY]
#262534
03/25/09 09:23 PM
03/25/09 09:23 PM
DemonDust
Menomonee Falls
Yep, but get your heims first before you drill it, I'm sure you will need the high angular heims
Now that we solved the tie rod angle problem.......
How did you cut and thread your tie rods? Since the main rod is alot bigger than the threaded part. I have the .500 UNF die and tap. Thats the biggest I have.
I was thinking maybe make them whatever thread is close to the original diameter?
[Re: DemonDust]
#262535
03/25/09 09:33 PM
03/25/09 09:33 PM
MR_P_BODY
I dont think you will need to shorten the shaft I think you will see that when you get done you will need a short coupler with a insert in each end(threaded inserts). I cant remember what the thread is on the rack but just use that and put one of the inserts in your coupler for that thread then the outer for the high angular heim ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Blucuda413]
#262537
03/25/09 09:46 PM
03/25/09 09:46 PM
Posts: 1,087 Northeast, Arkansas
Dodgeman67
Northeast, Arkansas
Dodgeman did you make those frame rails or did you some like S&W???
These were on the car when we got it, and they go up an extreme angle, I kinda wished I had cut it all off and just put one of the round tube front chassis clips on it.
[Re: Dodgeman67]
#262538
03/25/09 09:50 PM
03/25/09 09:50 PM
DemonDust
Menomonee Falls
After I mod my steering arms I'll know. But that is def what I would use. One problem though I can't scroll down on your screen ![](/ubbthreads/images/graemlins/laugh2.gif) Thanks for the info ![](/ubbthreads/images/graemlins/thumbs.gif) Big thanks to Mr P ![](/ubbthreads/images/graemlins/wave.gif) And HemiFred (where's that darn sheep smiley ![](/ubbthreads/images/graemlins/laugh2.gif) )
[Re: Dodgeman67]
#262540
03/25/09 10:05 PM
03/25/09 10:05 PM
DemonDust
Menomonee Falls
You can just go to C.E.'s website and go to rack and pinions and it's there.
Remember to rosette(sp) weld them as well as just welding them up.
So you drilled holes in the sleeves and plug welded them besides welding the end of the sleeve?
[Re: DemonDust]
#262541
03/25/09 10:07 PM
03/25/09 10:07 PM
Dodgeman67
Northeast, Arkansas
Yes, most definately do that. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: Dodgeman67]
#262542
03/25/09 10:14 PM
03/25/09 10:14 PM
MR_P_BODY
Yep, thats a must do ![](/ubbthreads/images/graemlins/wave.gif)
[Re: DemonDust]
#262544
03/25/09 10:25 PM
03/25/09 10:25 PM
Dodgeman67
Northeast, Arkansas
Chassis Engineering's has the ujoints as well, someone on here may be a dealer for them and can get you a better price. The mail order places also have them. I made a complete column for mine with the quick disconnect for the wheel. I use this local guy in Missouri and he can beat the mail order places, if there isn't someone on here, give Vernon a call. http://www.barkerracingservice.com/
