Converting a 12 volt ALTERNATOR to 16 volt***Please Reread** #2624627
02/22/19 11:50 AM
02/22/19 11:50 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
[/b]Going the 16 volt route now and have a 12 volt East Coast [b]Alternator.
They want $100.00 plus shipping both ways.
Is there a way to convert this on my own?
Where can you get the parts to convert?
Doesn't seem too hard.
Anyone ever do it?
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624628
02/22/19 11:57 AM
02/22/19 11:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Unless they're going to add 2 cells, it's a transformer.
Boffin Emeritus
Re: Converting a 12 volt battery to 16 volt [Re: polyspheric] #2624712
02/22/19 02:40 PM
02/22/19 02:40 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Buy it from Summit. Free shipping over $100
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624716
02/22/19 02:45 PM
02/22/19 02:45 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My Valiant had a Jacobs box on it that stepped up 12V to 14+. It's just a step-up transformer. I think Jacobs probably still makes them.
http://www.jacobselectronics.com.au/raceaccuvolt.htm
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624721
02/22/19 02:50 PM
02/22/19 02:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I assume you mean your alternator being converted to 16V from a 12V. I have done it both ways with an East Coast alternator. IMO just buy a new one and sell the 12V one. You end up in about the same place money wise.
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624738
02/22/19 03:39 PM
02/22/19 03:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
16v battery, alternator, battery charger for the shop, and make sure everything in the car is compatible. A fairly sizable investment, but a good one if your program can benefit. Not worth it to a lot of people.
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624776
02/22/19 05:07 PM
02/22/19 05:07 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I did back to back tests on the same day back when I was running 8.40’s in my Daytona and saw nothing. And that was before I started running an alternator.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624805
02/22/19 05:49 PM
02/22/19 05:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I would not expect to find any performance gains going from 16 volt from 12, not even a consideration. Why would it be?? My stuff cranks faster, cools better/quicker and takes longer to get to temp with 16V than it did with a 12v. The reason I wont do anything but 16V in a racecar anymore. Our dragster has 16V with an alternator and never needs to see the charger. Cools down in just a few minutes and cranks like mad. Same with the Stratus, just one 6lb 16V lithium in it, cranks considerably faster than it did with a 16V AGM.
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624807
02/22/19 05:51 PM
02/22/19 05:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I messed up the thread title. I want to convert my 12 volt East Coast ALTERNATOR to 16 volts. What parts do I need ?
Re: Converting a 12 volt battery to 16 volt [Re: Sammy] #2624811
02/22/19 05:59 PM
02/22/19 05:59 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
want to trade? I have a 16v East coast alternator I don't need any more. PM me...
