Spring for automatic column shift arm, need a new one #262462
03/22/09 09:47 PM
03/22/09 09:47 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Hey guys, I need to get the return spring for my autocatic column shifter arm. The coil spring that returns the handle after you pull it towards yourself to change gears, where can I get one? Mine is all broken and won't return the shifter. Thanks!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Spring for automatic column shift arm, need a new one [Re: itali83] #262463
03/22/09 10:20 PM
03/22/09 10:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I should have one if you want it.
