Aftermarket power window kit #2584607
11/29/18 11:29 AM
11/29/18 11:29 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
This looks pretty simple and the price is right. Anybody have any experience with it ?
ebay
Re: Aftermarket power window kit [Re: varunner] #2584635
11/29/18 12:49 PM
11/29/18 12:49 PM
Guitar Jones Offline
Please note this kit is designed to replace your factory window regulator and offer quick smooth performance. This kit is also designed to work on Dodge Challenger 1970 - 1974’s that have modified doors and channels.
eek Modified how exactly and that door glass isn't flat is it?
Re: Aftermarket power window kit [Re: varunner] #2584643
11/29/18 01:02 PM
11/29/18 01:02 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
yeah that second sentence makes you wonder, but it does say it replaces the factory regulator. Looks like they have sold 4 of them and I didn't see any negative feedback.
Re: Aftermarket power window kit [Re: varunner] #2584650
11/29/18 01:10 PM
11/29/18 01:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I used these a few times:
https://www.ebay.com/itm/Metra-Install-B...75.c10#viTabs_0
They work with your original crank window regulators and are super easy to install. Just be sure to find ones that are made by spal, another member commented the off-brand ones don't have enough jam to work the windows effectively. I used the spal ones and they worked fine on every vehicle I've done them in.
Re: Aftermarket power window kit [Re: DaytonaTurbo] #2584664
11/29/18 01:38 PM
11/29/18 01:38 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I like those. My driver's side regulator is shot, passenger side is ok, so a new driver's side reg and this kit should get me power windows on both sides for @ $350. thanks
Re: Aftermarket power window kit [Re: varunner] #2623378
02/19/19 04:31 PM
02/19/19 04:31 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I bought and installed the metra kit from Ebay. I have to say I'm impressed. Pretty simple kit and appears to be quality parts. Made in Italy. You need to buy switches and relays which adds $30 or so.
20190125_103609_1550594329127_resized.jpg20190127_155645_1550594327010_resized.jpg20190128_163234_1550594325081_resized.jpg
Re: Aftermarket power window kit [Re: varunner] #2623614
02/20/19 09:46 AM
02/20/19 09:46 AM
indy
70moparmike Offline
70moparmike  Offline
indy
couldn't find any switches on there website. where did you get yours? and are they on the knob that protrudes from the door panel? or a rocker switch?
Re: Aftermarket power window kit [Re: varunner] #2623622
02/20/19 10:41 AM
02/20/19 10:41 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I used rocker switches in a small electrical box where the console used to be. Car is race only. below are where I got the switches and relays, and a wiring diagram. The instructions and wiring diagram that comes with the kit aren't the best.
switches
relays
Re: Aftermarket power window kit [Re: varunner] #2623686
02/20/19 01:50 PM
02/20/19 01:50 PM
indy
70moparmike Offline
70moparmike  Offline
indy
i was thinking about a push button start system and they include running up windows and locking car when setting the alam mode? thought that would be cool to do..
Re: Aftermarket power window kit [Re: 70moparmike] #2623693
02/20/19 02:08 PM
02/20/19 02:08 PM
dogdays Offline
dogdays  Offline
OP, that Ebay kit looks very similar to what I found in the door of my Hyundai, except this one doesn't use cables which is a good thing.
It gets rid of the hand crank machinery completely and as most of that is pretty worn out by this time, good riddance. For that reason, the setups that turn the window crank aren't very attractive to me.
The only problem I could see was mentioned above, straight vs. curved. I hope the designers of the kit figured that out. I bet they did.
R.
Re: Aftermarket power window kit [Re: varunner] #2624054
02/21/19 01:51 AM
02/21/19 01:51 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've played with a lot of window lifts working on street rods and such. Unless the ebay setup is mounted so it can move with the window, I don't see it working well with curved glass. It moves straight up and down while the curved glass is moving in and out as it goes up and down. Something has to accommodate that in and out movement.
Buy a power window kit for curved glass. Gene
Re: Aftermarket power window kit [Re: varunner] #2624124
02/21/19 11:32 AM
02/21/19 11:32 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I bought the second kit mentioned, not the first one with the linear actuators. All it does is turn the hand crank. Everything in the door is OEM. Very simple
Re: Aftermarket power window kit [Re: varunner] #2624545
02/22/19 01:39 AM
02/22/19 01:39 AM
Illinois
SIX225 Offline
SIX225  Offline
Illinois
Might try this setup. https://youtu.be/1uG6grzdUf8
Re: Aftermarket power window kit [Re: SIX225] #2624723
02/22/19 02:55 PM
02/22/19 02:55 PM
moparx Online content
moparx  Online Content
my favorite [BY FAR !] repair guy ! up up up
beer
Re: Aftermarket power window kit [Re: varunner] #2628140
03/03/19 01:07 AM
03/03/19 01:07 AM
70duster340 Offline
70duster340  Offline
Would this kit work on an A body, specifically a 1970 Duster? Looks very intriguing to me.
Re: Aftermarket power window kit [Re: varunner] #2628242
03/03/19 01:40 PM
03/03/19 01:40 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
sure, no difference compared to what I did.
Re: Aftermarket power window kit [Re: varunner] #2628402
03/03/19 08:17 PM
03/03/19 08:17 PM
70duster340 Offline
70duster340  Offline
So I would assume that it necessitates removal of the window cracks? How is the hole in the door panels covered? Any pics?
Re: Aftermarket power window kit [Re: varunner] #2628495
03/03/19 11:57 PM
03/03/19 11:57 PM
70duster340 Offline
70duster340  Offline
Anybody?
Re: Aftermarket power window kit [Re: varunner] #2628694
03/04/19 02:52 PM
03/04/19 02:52 PM
70duster340 Offline
70duster340  Offline
Hello???
Re: Aftermarket power window kit [Re: 70duster340] #2628903
03/04/19 11:16 PM
03/04/19 11:16 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Come on man... the pictures posted already answer your questions. But so I don't look too much of a jerk.... violin
1) Yes the window cranks need to be removed rolleyes
2) There is a black cap that goes over the hole, you can see it in the link for the kit, posted above... rolleyes It does look a little cheesy, but it's a universal kit.
GoodBye wave
