Re: 17 inch wheels on 69 gtx ?
[Re: 70moparmike]
#2624131
02/21/19 11:43 AM
02/21/19 11:43 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A lot of it deends on th etire too.
If you are going to use a stock height tire that isn't too wide stock offsets work fine. If you are going to go with a max size that can be stuffed in there tire you will need wider rims and you will need to measure your ride to see what will fit because body tolerances are sloppy.
[Re: 70moparmike]
#2624143
02/21/19 12:24 PM
02/21/19 12:24 PM
Posts: 12,141 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Take a 2'x 3' piece of cardboard and tape it to the floor under the wheel well opening. Then use a plumb bob and mark all the edges of the opening including the hub on the cardboard.
Do both sides as they can vary.
This will give you a very accurate footprint that can be easily measured. And when I order wheels, I always order them about 1/8 inch extra to the inside. That way, if they need any 'adjustment' when they arrive, they can be shimmed outward a lot easier than they can be brought farther inward.
Master, again and still
[Re: 70moparmike]
#2624212
02/21/19 02:40 PM
02/21/19 02:40 PM
Posts: 20,813 A collage of whims
topside
A collage of whims
There's a few ways to figure this out:
1.Dave's plumb bob method is good. 2.Mount a wheel (no tire) up, support car by suspension, break out the measuring tape. 3.Wait for guys here to chime in with what they've done, which may or may not work for you. 4. Get specs for the wheels & tires you like; for tires, section width, OD and rim widths recommended and used for measuring.
'68-'70 B-body rears typically use a 4.25-4.5" BS up to 8.5" wide, after that 5.0-5.5" gets a 10" rim in there. Usually 29" is about max OD, max section width that fits is around 12.5-13.0"...BUT as stated cars vary, including side-to-side.
[Re: topside]
#2624296
02/21/19 05:15 PM
02/21/19 05:15 PM
Posts: 5,105 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
You really need to measure accurately and add for tire bulge when trying to determine backspace... On my 70 I think I've heard others say the wheel well opening is larger than a 69. I have 275/60/17's on the back of mine and it is stuffed...I also had to slide the rear end back with a spacer in front of the spring perch for the tires to clear the front bottom edge of the 1/4 panel. These tires I have measure 30" tall and have a 11 1/2" section width.... They are on 17 x 9 1/2 in rims with 5 1/2" of backspacing. After the first year I ended up using a 1/4" wheel spacer behind them. They only ever rubbed on angled odd entrances and exits... Using a 5" backspace would be conservative towards the spring side...and as mentioned above tire bulge and the overall length of your rear will change everything.
...FAFO...
[Re: 70moparmike]
#2624867
02/22/19 08:31 PM
02/22/19 08:31 PM
skicker
"The Champ"
"The Champ"
Western Md.
what size did you use on the front? Tires are 215/70/15's Wheels are 15x7...I think they're a 3" or so backspacing...
...FAFO...
