New slant six blower #2623721
02/20/19 03:00 PM
02/20/19 03:00 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Just seen this blower for the slant guys.
http://www.torqstorm.com/supercharger_kit_slant_6.html
Gus beer
64 Plymouth Savoy
Dana 60
Re: New slant six blower [Re: fourgearsavoy] #2623750
02/20/19 03:55 PM
02/20/19 03:55 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Econo dragster maybe?
Re: New slant six blower [Re: fourgearsavoy] #2623793
02/20/19 05:24 PM
02/20/19 05:24 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I like it. I used to have a b&m 144 super charger on a slant. Always had trouble keeping the intake gasket sealed over 5 psi of boost.
Re: New slant six blower [Re: fourgearsavoy] #2623798
02/20/19 05:30 PM
02/20/19 05:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Those have been out for awhile. Kit is reasonably cheap, and a few are out there. I've been thinking about one for my junk. Buddy of mine has one he's putting in a '64 Dart. I'm watching closely.
Re: New slant six blower [Re: fourgearsavoy] #2623799
02/20/19 05:31 PM
02/20/19 05:31 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Luke Duke was running a boosted Slant Six in the 80s, before boosted became a thing. Turbo and roots I believe.
Re: New slant six blower [Re: fourgearsavoy] #2624048
02/21/19 01:33 AM
02/21/19 01:33 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
My friend Mad Mike turned his Dodge into an AWB,it's started with a little and blow through and grew to a larger turbo and a Big Stuff 3 eek
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: New slant six blower [Re: fourgearsavoy] #2624052
02/21/19 01:48 AM
02/21/19 01:48 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Re: New slant six blower [Re: CMcAllister] #2624100
02/21/19 09:09 AM
02/21/19 09:09 AM
Sharpsburg Maryland
440farmer Offline
440farmer  Offline
Sharpsburg Maryland
Yeah I remember him he had roots type blower driven by v belt
and from what I can recall the damn thing ran pretty good.
He was certainly a character even broke down his wheels and tires to run slicks for the day...
Re: New slant six blower [Re: fourgearsavoy] #2624159
02/21/19 01:08 PM
02/21/19 01:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
A centrifugal makes a better package than roots.
1. can be intercooled (as a blow-through)
2. no visible mods (like that giant cop-magnet hole in the hood)
3. weighs less
4. requires less parasitic drag per pound of boost
5. lower charge temperature
Disadvantage: not much torque increases until it's spun up, so it needs a looser convert to launch.
Advantage over NA: equal and tuned header length is relatively unimportant, but should use primary OD based on power delivered, not engine size.
Boffin Emeritus
Re: New slant six blower [Re: fourgearsavoy] #2624188
02/21/19 01:46 PM
02/21/19 01:46 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Re: New slant six blower [Re: gzig5] #2624192
02/21/19 02:02 PM
02/21/19 02:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Originally Posted By gzig5
I have 2 of those in my shop now. I will be building a mounting plate and carb mount for a draw through setup. Not the most efficient power wise, but it will look cool at the cruise nights he goes to.
Re: New slant six blower [Re: polyspheric] #2624290
02/21/19 04:54 PM
02/21/19 04:54 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
3. weighs less
Not many seem to understand the hows and whys of #5
Re: New slant six blower [Re: jcc] #2624314
02/21/19 06:00 PM
02/21/19 06:00 PM
dogdays Offline
dogdays  Offline
Power increased from 90 to 120 on this engine.
R.
Re: New slant six blower [Re: 440farmer] #2624365
02/21/19 07:56 PM
02/21/19 07:56 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
He's world famous with old 75&80 guys. I'm not even gonna say what he's up to these days.
Re: New slant six blower [Re: 440farmer] #2624483
02/21/19 11:36 PM
02/21/19 11:36 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
[/quote] He was certainly a character even broke down his wheels and tires to run slicks for the day... [/quote]
I remember offering him a set of rims at capitol once so he wouldn't have to do that, he declined. He was definitely ahead of his time with the turbo stuff. Think the last setup that car had was turbo small block.
Re: New slant six blower [Re: fourgearsavoy] #2624635
02/22/19 12:14 PM
02/22/19 12:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
An Eaton works very well (lighter, smaller, cheaper, and more efficient than GMC 4-71 etc.) but the plumbing has to be doped out. Easiest is blow-through with just a filter to replace the TB, but you need to make a box to cover the entire discharge side and adapt to your intake. I've seen pictures (no details) of a 90° turn at the TB for a 4 bbl. adapter. The Eaton case can be rotated 90° or 180° to make plumbing easier.
Needs no external lubrication or drain.
Probably works with aftermarket 6 rib belt kits.
There are several nose drive lengths available so that the discharge window can be put (more or less) where you want it.
The Eaton M numbers are the charge volume of 1 rotation: M90 is 90" (about right for moderate boost on a slant), etc. and typically turn 2 to 3 × engine speed.
More of my comments on my site: http://victorylibrary.com/mopar/blower/blower.htm
Boffin Emeritus
