Starter Relay Run Terminal ? #2623395
02/19/19 05:34 PM
02/19/19 05:34 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Brain fade I suppose, and not near the car or FSM.
Want to use a 12V switched terminal for an added tach, and since I'm running the coil & neg leads to the engine, I'm thinking running the tach power to the SR would be clever & easier than pulling the ign switch. Also easier to deal with should I later remove the tach.
'68 Road Runner 4-speed car if that matters.
Thanks.
Re: Starter Relay Run Terminal ? [Re: topside] #2623398
02/19/19 05:45 PM
02/19/19 05:45 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I'd look for another source, as none of the starter relay terminals are "run only" power.
Re: Starter Relay Run Terminal ? [Re: topside] #2623402
02/19/19 06:04 PM
02/19/19 06:04 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You could just hook it to a fuse box terminal. No need to pull the ignition switch.Use one of these.
Re: Starter Relay Run Terminal ? [Re: topside] #2623421
02/19/19 07:33 PM
02/19/19 07:33 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
Thanks, Buildanother.
Stumpy, I've done the fuse box tap before by modifying a spade connector, but was never all that impressed with it.
Never seen the clip you posted, that's pretty clever.
Re: Starter Relay Run Terminal ? [Re: topside] #2623433
02/19/19 08:20 PM
02/19/19 08:20 PM
Grand Prairie,Texas
Grand Prairie,Texas
Available at most parts stores.
Re: Starter Relay Run Terminal ? [Re: stumpy] #2623459
02/19/19 09:57 PM
02/19/19 09:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A "run" terminal in the fuse box? I think all you'll find there is ACC and BAT. Using ACC in the fuse panel will power the tach in accessory position. Best to use the blue wire on the voltage regulator for RUN power.
Re: Starter Relay Run Terminal ? [Re: topside] #2623581
02/20/19 02:44 AM
02/20/19 02:44 AM
Grand Prairie,Texas
Grand Prairie,Texas
There are key on powered fuses.
Re: Starter Relay Run Terminal ? [Re: stumpy] #2623723
02/20/19 03:04 PM
02/20/19 03:04 PM
& make sure how you feed it (the 12V) goes thru a fuse or add an inline fuse (5amp?).
Re: Starter Relay Run Terminal ? [Re: stumpy] #2623748
02/20/19 03:53 PM
02/20/19 03:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Where? What circuit? All key-on circuits in the fuse box are accessories, not RUN.
Re: Starter Relay Run Terminal ? [Re: John_Kunkel] #2623756
02/20/19 04:02 PM
02/20/19 04:02 PM
If I'm remembering correctly the radio, heater and several other circuits that are in the fuse box are run only with the key in the on position, correct work
OP you can remove the Phillip head screw that holds the fuse box onto the dash frame and drop it down so you can pull the plastic dust cover off the back side and use one of the unused spade tip to feed your tach with the key on scope
Re: Starter Relay Run Terminal ? [Re: Cab_Burge] #2623759
02/20/19 04:05 PM
02/20/19 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ever turn the key to ACC just to listen to the radio with the engine off? Yes, ACC circuits are powered with the key in RUN but a tach should be powered by a dedicated RUN circuit otherwise it will be powered with the key in ACC.
Re: Starter Relay Run Terminal ? [Re: topside] #2623792
02/20/19 05:22 PM
02/20/19 05:22 PM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
John, I like the Run side of the voltage reg; easy to piggy-back, and no doubt what's what. Plus I have some OEM-style connectors. I figure a 5A fuse like Robert says is wise.
Back in the day running the power from the fusebox, maybe the thing that saved me was (a) I almost never use the Acc key position or (b) I picked up the power from the On side of the fuse?
Thanks, guys.
For the record, the repro in-dash tach is no more accurate than they were back in the day, it's more entertainment than factual.
Re: Starter Relay Run Terminal ? [Re: topside] #2623805
02/20/19 05:48 PM
02/20/19 05:48 PM
Grand Prairie,Texas
Grand Prairie,Texas
what harm is there in having the tach powered in acc?
Re: Starter Relay Run Terminal ? [Re: stumpy] #2623823
02/20/19 06:07 PM
02/20/19 06:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It freaks out your OCD
I prefer to use the VR run source to trigger relays that provide power to whatever source needs it in run. Don't like to load down the VR run line as it will affect the VR's operation and MoPar's charging system isn't all that sophisticated.
Don't be the exception.
