Jesel sent me this pic today #2623139
02/19/19 12:07 AM
02/19/19 12:07 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
I run @g3hemiswap on instagram. Jesel sent me this pic today.
Notice the cnc port job. Im trying to find out who's port it is
Re: Jesel sent me this pic today [Re: sixpackgut] #2623220
02/19/19 06:08 AM
02/19/19 06:08 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Heads are ThiTek , I have a set here that has the same Vane done by Frankenstein 210CC 2.20 intake valve going on a 441CI BGE
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Jesel sent me this pic today [Re: ric3xrt] #2623245
02/19/19 11:17 AM
02/19/19 11:17 AM
Charleston
Charleston
cool
Re: Jesel sent me this pic today [Re: sixpackgut] #2623259
02/19/19 12:02 PM
02/19/19 12:02 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
After blowing the Pic up I can see the roughness of casting
Re: Jesel sent me this pic today [Re: ric3xrt] #2623266
02/19/19 12:25 PM
02/19/19 12:25 PM
Charleston
Charleston
I wonder if it's a completely different casting. I have a picture of the old Drag Pack head that Barton went in the 8.50s with and there was really not very much metal removed from the port at all. That wing in the picture looks very tall.
Also, the new factory stock motors have lifters angles or placement different than stock
Re: Jesel sent me this pic today [Re: sixpackgut] #2623365
02/19/19 03:54 PM
02/19/19 03:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice.
Re: Jesel sent me this pic today [Re: HotRodDave] #2623401
02/19/19 06:01 PM
02/19/19 06:01 PM
Charleston
Charleston
As far as I know, in factory stock, machining and moving things around is not allowed. However, the factory stock motors do use a different lifter layout so everything might be part of a approved by nhra package. Im sure that is a boat load of money in that picture though.
Re: Jesel sent me this pic today [Re: HotRodDave] #2623412
02/19/19 07:09 PM
02/19/19 07:09 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Was told 250.00 a rocker.
Re: Jesel sent me this pic today [Re: sixpackgut] #2623450
02/19/19 09:17 PM
02/19/19 09:17 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Those rockers are for the Facory Stock latest and greatest stuff. T & D has that design too.
Re: Jesel sent me this pic today [Re: STEFF] #2623457
02/19/19 09:49 PM
02/19/19 09:49 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
That’s some pretty stuff right there. Man jewelry
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Jesel sent me this pic today [Re: sixpackgut] #2623539
02/20/19 12:42 AM
02/20/19 12:42 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
We experimented with a welded fin, but it never took off for us. The tester dropped the ball.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Jesel sent me this pic today [Re: AlexP] #2623553
02/20/19 01:29 AM
02/20/19 01:29 AM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
From what I've seen on the flow bench, and measuring the CSA with and without the vane on the floor, it speeds the air up too much unless your keeping the lift below .550 and rpm range (typical 5.7 - 6.4 cid)below 6000.
We've found really good flow and power (5.7 eagle head, 6.1, and 6.4 heads)getting creative with the valve job/bowl/chamber area.
We also measure rev. flow on the intake up to .250 lift and make sure it's in check.
Brian
Brian Hafliger
Re: Jesel sent me this pic today [Re: MattW] #2624280
02/21/19 04:33 PM
02/21/19 04:33 PM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Here's the quote I got Monday
Rick
Lead time is about 3-4 weeks and the racer price for 16 rockers and our retaining kit is $4515.00
Jon Fodor
JESEL, Inc.
thank god it's not my check book.
Re: Jesel sent me this pic today [Re: ric3xrt] #2624320
02/21/19 06:10 PM
02/21/19 06:10 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
What kind of lift is possible with these?
Re: Jesel sent me this pic today [Re: ric3xrt] #2624373
02/21/19 08:15 PM
02/21/19 08:15 PM
PA.
"Little"John
"Little"John
PA.
Rick
Jon Fodor
JESEL, Inc.
Quick would someone please hand me my nitro pills.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Jesel sent me this pic today [Re: WO23Coronet] #2624535
02/22/19 01:17 AM
02/22/19 01:17 AM
STEFF Offline
STEFF  Offline
Stock ratio.
Re: Jesel sent me this pic today [Re: STEFF] #2624655
02/22/19 12:49 PM
02/22/19 12:49 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Okay they're stock ratio but can they handle more lift than the stock stuff? I think stock stuff gets iffy around the .650" mark?
Re: Jesel sent me this pic today [Re: sixpackgut] #2624749
02/22/19 04:00 PM
02/22/19 04:00 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably not as the problem would be the same, the tip of the rocker getting too close to the edge of the valve. They would need to move the pivot point away from the valve to get a longer arm, thats kind of hard to do with the spark plug tubes right there. Maybe .050 or .100 or so and at the same time that could be used to increase the rocker ratio but any way you slice it there is not a lot of room in the top of the head on these things, the good thing is that .650 can access a ton of flow.
Re: Jesel sent me this pic today [Re: HotRodDave] #2624928
02/22/19 11:34 PM
02/22/19 11:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I thought part of the reason for upgrading to Jesel/T&D was for more lift? Kind of seems like a waste as don’t guys turn 7500ish with stock stuff?
Re: Jesel sent me this pic today [Re: sixpackgut] #2625280
02/24/19 12:20 AM
02/24/19 12:20 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Probably geared more toward the 9000+ RPM guys is my guess.
