472 hemi..issues, follow up hot472 hemi
#2623419
02/19/19 07:33 PM
02/19/19 07:33 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
the hemi that is running hot all the time...i tore into the hemi today, as my previous post was all with visual inspection, come to find out it is an all aluminum engine,painted . with a solid roller cam(unknown specs.) the past life is unknown.. i cut the filter, it looks good, no metal i did a comp test all real similar..120ish 1st pump 145ish 3rd pump . i did a leak down and it ranged from 38-44% on a warm engine. when idling smoke puffs from both breathers and dip stick tube, i let it idle until the t-stat opened 180 then let it cool a bit before leak down, so if this was your hemi.. what would you do next
Re: 472 hemi..issues, follow up hot472 hemi
[Re: mcat4321]
#2623456
02/19/19 09:41 PM
02/19/19 09:41 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Since it’s together and running, I’d make as sure as I could the cooling system was functioning correctly before I started tearing stuff apart.
[Re: mcat4321]
#2623659
02/20/19 12:45 PM
02/20/19 12:45 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
My World aluminum block required a head gasket that had different coolant holes on the bottom row. I got the correct part no. From Rich Nedbal AKA Mopar Rich. I had to order them from Cometic.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2623839
02/20/19 06:27 PM
02/20/19 06:27 PM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
Mark Sounds like the KB gaskets also. The KB block has the outer row of steam holes relocated away from the bore requiring a special head gasket and relocating the holes in the heads.
[Re: an8sec70cuda]
#2623951
02/20/19 10:25 PM
02/20/19 10:25 PM
Posts: 43,195 Bend,OR USA
Cab_Burge
Mark Sounds like the KB gaskets also. The KB block has the outer row of steam holes relocated away from the bore requiring a special head gasket and relocating the holes in the heads. I had a head gasket sealing problem with the only KB street hemi block I assembled for a customer due to the sleeve height being to high at first and then those dang cooling water holes being so close the sleeves in the block I ended up having to take the block and heads to SCE gasket company in Lancaster, CA to have them make me some copper head gaskets that would work properly All the other head gaskets I had bought and tried where for the race KB blocks, not the street block
