Jesel sent me this pic today
#2623139
02/19/19 12:07 AM
02/19/19 12:07 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I run @g3hemiswap on instagram. Jesel sent me this pic today.
Notice the cnc port job. Im trying to find out who's port it is
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: Jesel sent me this pic today
[Re: sixpackgut]
#2623220
02/19/19 06:08 AM
02/19/19 06:08 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Heads are ThiTek , I have a set here that has the same Vane done by Frankenstein 210CC 2.20 intake valve going on a 441CI BGE
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: sixpackgut]
#2623259
02/19/19 12:02 PM
02/19/19 12:02 PM
ric3xrt
Trumbauersville PA
After blowing the Pic up I can see the roughness of casting
[Re: ric3xrt]
#2623266
02/19/19 12:25 PM
02/19/19 12:25 PM
sixpackgut
Charleston
After blowing the Pic up I can see the roughness of casting I wonder if it's a completely different casting. I have a picture of the old Drag Pack head that Barton went in the 8.50s with and there was really not very much metal removed from the port at all. That wing in the picture looks very tall. Also, the new factory stock motors have lifters angles or placement different than stock
[Re: sixpackgut]
#2623365
02/19/19 03:54 PM
02/19/19 03:54 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice.
[Re: HotRodDave]
#2623401
02/19/19 06:01 PM
02/19/19 06:01 PM
sixpackgut
Charleston
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice. As far as I know, in factory stock, machining and moving things around is not allowed. However, the factory stock motors do use a different lifter layout so everything might be part of a approved by nhra package. Im sure that is a boat load of money in that picture though.
[Re: HotRodDave]
#2623412
02/19/19 07:09 PM
02/19/19 07:09 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice. Was told 250.00 a rocker.
[Re: STEFF]
#2623457
02/19/19 09:49 PM
02/19/19 09:49 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That’s some pretty stuff right there. Man jewelry
[Re: AlexP]
#2623553
02/20/19 01:29 AM
02/20/19 01:29 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
From what I've seen on the flow bench, and measuring the CSA with and without the vane on the floor, it speeds the air up too much unless your keeping the lift below .550 and rpm range (typical 5.7 - 6.4 cid)below 6000. We've found really good flow and power (5.7 eagle head, 6.1, and 6.4 heads)getting creative with the valve job/bowl/chamber area.
We also measure rev. flow on the intake up to .250 lift and make sure it's in check. Brian
Brian Hafliger
[Re: MattW]
#2624280
02/21/19 04:33 PM
02/21/19 04:33 PM
ric3xrt
Trumbauersville PA
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice. Was told 250.00 a rocker. Here's the quote I got Monday Rick Lead time is about 3-4 weeks and the racer price for 16 rockers and our retaining kit is $4515.00 Jon Fodor JESEL, Inc. thank god it's not my check book.
[Re: ric3xrt]
#2624373
02/21/19 08:15 PM
02/21/19 08:15 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
For people thinking those rockers might be remotely budget friendly are going to have to keep dreaming, they will be expensive to buy, head will need machine work and non stock style lifters will be needed but for high end stuff they look really nice. Was told 250.00 a rocker. Here's the quote I got Monday Rick Lead time is about 3-4 weeks and the racer price for 16 rockers and our retaining kit is $4515.00 Jon Fodor JESEL, Inc. thank god it's not my check book. Quick would someone please hand me my nitro pills.
[Re: sixpackgut]
#2624749
02/22/19 04:00 PM
02/22/19 04:00 PM
HotRodDave
Kalispell Mt.
Probably not as the problem would be the same, the tip of the rocker getting too close to the edge of the valve. They would need to move the pivot point away from the valve to get a longer arm, thats kind of hard to do with the spark plug tubes right there. Maybe .050 or .100 or so and at the same time that could be used to increase the rocker ratio but any way you slice it there is not a lot of room in the top of the head on these things, the good thing is that .650 can access a ton of flow.
[Re: sixpackgut]
#2625280
02/24/19 12:20 AM
02/24/19 12:20 AM
HotRodDave
Kalispell Mt.
Probably geared more toward the 9000+ RPM guys is my guess.
