Re: Starter Relay Run Terminal ?
[Re: stumpy]
#2623459
02/19/19 09:57 PM
02/19/19 09:57 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You could just hook it to a fuse box terminal. No need to pull the ignition switch.Use one of these. A "run" terminal in the fuse box? I think all you'll find there is ACC and BAT. Using ACC in the fuse panel will power the tach in accessory position. Best to use the blue wire on the voltage regulator for RUN power.
[Re: stumpy]
#2623723
02/20/19 03:04 PM
02/20/19 03:04 PM
RapidRobert
& make sure how you feed it (the 12V) goes thru a fuse or add an inline fuse (5amp?).
[Re: stumpy]
#2623748
02/20/19 03:53 PM
02/20/19 03:53 PM
John_Kunkel
Rio Linda, CA
There are key on powered fuses. Where? What circuit? All key-on circuits in the fuse box are accessories, not RUN.
[Re: Cab_Burge]
#2623759
02/20/19 04:05 PM
02/20/19 04:05 PM
John_Kunkel
Rio Linda, CA
Ever turn the key to ACC just to listen to the radio with the engine off? Yes, ACC circuits are powered with the key in RUN but a tach should be powered by a dedicated RUN circuit otherwise it will be powered with the key in ACC.
[Re: stumpy]
#2623823
02/20/19 06:07 PM
02/20/19 06:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
what harm is there in having the tach powered in acc? It freaks out your OCD I prefer to use the VR run source to trigger relays that provide power to whatever source needs it in run. Don't like to load down the VR run line as it will affect the VR's operation and MoPar's charging system isn't all that sophisticated.
