How to get code off this fender tag ? #2622648
02/17/19 07:20 PM
02/17/19 07:20 PM
Near Columbus, Ohio
++MAX WEDGE++ Offline OP
Near Columbus, Ohio
Hello all,
How can I tell what codes are on this fender tag? Any body out there that would be able to help get the missing codes as well? LMK your thought's. Thanks in advance.
shruggy
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622652
02/17/19 07:27 PM
02/17/19 07:27 PM
CA
crackedback Offline
crackedback  Offline
CA
Look at the backside.
Re: How to get code off this fender tag ? [Re: crackedback] #2622674
02/17/19 08:21 PM
02/17/19 08:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes, post a pic of the backside
JB Rhinehart, Realist
A-Body's RULE!
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622684
02/17/19 08:38 PM
02/17/19 08:38 PM
Martinsville, IN
cdwmotorsports Online content
cdwmotorsports  Online Content
Martinsville, IN
What those two intelligent men said...
If you are wanting to clean it up Id start with evaporust or a brass bristle brush and a gentle hand
Whats that from?
Its really difficult to tell if that's rust or orange peeling black paint.
My best guess so far is this
V6X V8X EN1
M21 N23 D?? V21
51 G11 G36 J5?
G4X9 12 4 1802
4 566
eBay-cdwmotorsports
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622696
02/17/19 09:30 PM
02/17/19 09:30 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Looks like a Challenger
2011 Drag Pak Challenger
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622701
02/17/19 09:42 PM
02/17/19 09:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
72 Demon perhaps?
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622728
02/17/19 11:02 PM
02/17/19 11:02 PM
Near Columbus, Ohio
Near Columbus, Ohio
Thanks for the help everybody I really apricate it. It's from a 72 duster twister car. Ill get photos of the back side and post asap.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2622869
02/18/19 12:15 PM
02/18/19 12:15 PM
MN, USA
69hurstsc Offline
69hurstsc  Offline
MN, USA
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623055
02/18/19 09:07 PM
02/18/19 09:07 PM
Near Columbus, Ohio
Near Columbus, Ohio
*UPDATED*
Here is the back side of fender tag.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623172
02/19/19 01:07 AM
02/19/19 01:07 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Probably not 100% accurate but with some interpretive guesswork this should be pretty close.
VL29: Plymouth Duster - Base/low level model
G = 318 V8
2 = 1972 model year
B = Plant = Hamtramck, MI, USA
405664 =Sequence number
E44 = 318 2 barrel V8 230hp
D13 = 3 Speed Manual Transmission-Floor Shift
EV2 = Hemi Orange Exterior Color
C4X9 = Trim - Vinyl Split Bench Seat = Black
TX9 = Black Upper Door Frames
418 = Scheduled Production Build Date = April, 18 1972
411902 = Order number
EV2 = Hemi Orange Roof Color
U = USA Specifications
A51 = Duster "Twister" Package
G11 = Tinted Glass (all)
G36 = OS Dual Racing Mirrors
J54 = Sport Hood
M25 = Wide sill moldings
L31 = Hood/Fender Mounted Turn Signals
M21 = Roof drip rail moldings
N23 = Electronic Ignition System
R11 = Radio Solid State AM (2 Watts)
V21 = Performance Hood Treatment
V6X = Body Side Stripes, Black
V8X = Tranverse Stripes, Black
EN1 = End of Sales Codes
Re: How to get code off this fender tag ? [Re: ScottSmith_Harms] #2623229
02/19/19 10:05 AM
02/19/19 10:05 AM
Near Columbus, Ohio
Near Columbus, Ohio
eek
HOLY COW !!!! Mr. Harms you are a Mopar Legend..... I'm not to sure how you did it, but that's spot on.
Thank you sir, and everyone here on Moparts for your help I am very grateful.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623264
02/19/19 12:19 PM
02/19/19 12:19 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
whistling
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623340
02/19/19 03:11 PM
02/19/19 03:11 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
soak it in vinegar
Re: How to get code off this fender tag ? [Re: moparsquid] #2623352
02/19/19 03:29 PM
02/19/19 03:29 PM
dogdays Offline
dogdays  Offline
I'm afraid that acid like vinegar will dissolve the rust which is all that's left of certain areas.
Sounds like it was a cool car for a budget model.
I'd degrease it and spray what you have with clear polyurethane. Then store it safely along with a copy or two of the translation AND some really good digital photos. That way if you decide it has collector value you'll have as much as possible of the original plate.
R.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623440
02/19/19 08:34 PM
02/19/19 08:34 PM
Near Columbus, Ohio
Near Columbus, Ohio
Thanks guys, that's amazing on how you all did that. What do you think production numbers (how Many) are? How many of these were made?
Very grateful for all the help
Re: How to get code off this fender tag ? [Re: 6bblgt] #2623441
02/19/19 08:35 PM
02/19/19 08:35 PM
Near Columbus, Ohio
Near Columbus, Ohio
Originally Posted By 6bblgt
whistling
That is super nice 6bblget. You Rock..... up
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623443
02/19/19 08:40 PM
02/19/19 08:40 PM
Near Columbus, Ohio
Near Columbus, Ohio
Will do sir.
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623497
02/19/19 11:26 PM
02/19/19 11:26 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If you decide to soak it to remove the rust I'd recommend Evaporust not acid (vinegar). Also, Dan's tag decipher may be more accurate concerning the L25 vs M25. Does your car have a trunk light? Rocker moldings?
Re: How to get code off this fender tag ? [Re: cdwmotorsports] #2623499
02/19/19 11:27 PM
02/19/19 11:27 PM
Martinsville, IN
Martinsville, IN
Whats that from?
V6X V8X EN1
M21 N23 D?? V21
51 G11 G36 J5?
G4X9 12 4 1802
4 566
I feel pretty good with what I had pre back of tag pics. That thing was difficult to read at best. Awesome job to those that got the whole thing.
To 6bblgt how did you make that “white fender plate image”?
eBay-cdwmotorsports
Re: How to get code off this fender tag ? [Re: ++MAX WEDGE++] #2623501
02/19/19 11:29 PM
02/19/19 11:29 PM
Martinsville, IN
Martinsville, IN
If ever there was a car that needed a new fender tag made.
What’s the rest of the car look like?
eBay-cdwmotorsports
