Painting dash 1969 Charger #2623030
02/18/19 07:38 PM
02/18/19 07:38 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I saw on GYC that you use a different paint on the top of the dash to eliminate glare.. I'm going to paint mine black. What paint is it you use to stop the glare? Thanks.. 1969 Charger
Re: Painting dash [Re: JohnH] #2623051
02/18/19 08:36 PM
02/18/19 08:36 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What kind and year car?
Re: Painting dash [Re: JohnH] #2623133
02/18/19 11:53 PM
02/18/19 11:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Use a semi gloss or a flat paint in what ever color you like, to eliminate glare from a painted dash. Its the high gloss that causes the glare. Gene
Re: Painting dash [Re: JohnH] #2623272
02/19/19 12:37 PM
02/19/19 12:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Original suede finish eliminates glare.
Re: Painting dash [Re: Stanton] #2623467
02/19/19 10:34 PM
02/19/19 10:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
And will add the entire dash was the same finish beer
Re: Painting dash [Re: Stanton] #2623469
02/19/19 10:40 PM
02/19/19 10:40 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
do it right..... just saying...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Painting dash [Re: JohnH] #2623471
02/19/19 10:42 PM
02/19/19 10:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
There is no different paint on the top of the dash. All of the dash frame metal has the same color and finish.
Re: Painting dash [Re: JohnH] #2623476
02/19/19 10:50 PM
02/19/19 10:50 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Painting dash [Re: NANKET] #2623482
02/19/19 11:01 PM
02/19/19 11:01 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Yes.... I don't think GYC paints two different paints....its all suede...
Instruments Speciltes sells it... you can reproduce to some extent...
Re: Painting dash [Re: JohnH] #2623981
02/20/19 11:29 PM
02/20/19 11:29 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Thanks for all feed backs.. That help me..
Re: Painting dash [Re: JohnH] #2624148
02/21/19 12:34 PM
02/21/19 12:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
With today's modern paints, it is difficult to get them as flat as necessary without them going toward the gray shade because the flattening agent is white and it takes quite a bit of it.
The original paint also had a bit of texture to further reduce glare.
Master, again and still
Re: Painting dash [Re: JohnH] #2624220
02/21/19 02:54 PM
02/21/19 02:54 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
But...you have to remove the VIN tag to properly paint the dash, right?
A few people have said not nice things about doing that.
Rich H.
Esse Quam Videri
Re: Painting dash [Re: ZIPPY] #2624226
02/21/19 03:08 PM
02/21/19 03:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If the condition is good enough it can be carefully taped around, otherwise I have done it, Painted it, re-screened the logo and reinstalled with the correct rivets. Same tag that the car was assigned when new. I don't see a problem with it. Swapping tags? different story twocents beer
Re: Painting dash [Re: TJP] #2624317
02/21/19 06:04 PM
02/21/19 06:04 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
What I did. Be prepared to pay for the correct rivets...
Re: Painting dash 1969 Charger [Re: JohnH] #2624537
02/22/19 01:25 AM
02/22/19 01:25 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Who gives a damn what a couple old maids think. Its your car, do as you see fit. As for the rivets, there are some people who think they're rare and ask outrageous prices but I've seen them all over the place for $30 a pair which I think is reasonable.
The suede finish can still be mixed by any paint distributor who is still allowed to sell lacquer (the Ditzler code applies to lacquer). You can still buy it in Michigan - not sure which other states. The downside is you have to buy a quart at roughly $100.. I've considered doing this and then repackaging it in smaller quantities.
