Radiator-Support-to-K-frame bracket - orientation? #2622672
02/17/19 08:18 PM
02/17/19 08:18 PM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Hi all,
This is the bracket which runs from the bottom of the radiator support (under the radiator) to the hole on the front lip of the K-frame. Which end should face forward? I'm trying to put it back on the way it was when I took my car apart, but it doesn't seem correct to me. Unfortunately, I'm unable to find this bracket in either the 1971 Chassis or Body Manuals.
In the pic (of a 1970 bracket) below, it appears that the left end attaches to the Radiator Support, and the right end to the K-frame. Is that correct? Also, does the K-frame end attach on top of the K-frame lip, or from the bottom? Thanks for any hints.
Roger
Re: Radiator-Support-to-K-frame bracket - orientation? [Re: Fab64] #2622716
02/17/19 10:24 PM
02/17/19 10:24 PM
West Central Wi.
1969 HEMI R-T Online content
1969 HEMI R-T  Online Content
West Central Wi.
Yes, the K frame end (round hole) uses a 1/4" U-nut. the extra long 1/4"x20 bolt goes thru from the bottom on this end.
HEMI,S ARE FOREVER!!!
Re: Radiator-Support-to-K-frame bracket - orientation? [Re: 1969 HEMI R-T] #2622825
02/18/19 05:08 AM
02/18/19 05:08 AM
So Cal, USA
Fab64 Offline OP
Fab64  Offline OP
So Cal, USA
Thanks for confirming. beer
